asus U35JC REV 2.0 - NVIDIA NEED bios
  • casti3l
    • Mar 2014
    • 95
    • romania
    model : U35JC-RX070V
    need bios dump with CLEAN ME
    pls!!!
  • cacla
    • Apr 2015
    • 442
    Re: asus U35JC REV 2.0 - NVIDIA NEED bios
    try this one
    • casti3l
      • Mar 2014
      • 95
      • romania
      i will try tomorow . thank you
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
      • Ahari
        by Ahari
        I...
        08-13-2025, 06:12 AM
      • jbonavita
        by jbonavita
        Some issues
        Things I tried
        04-29-2025, 09:38 PM
      • kodox
        Asus ExpertBook B1400CB Bios Dump Needed
        by kodox
        need original bios dump, original bios has flashed by other technician before me.
        attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
        unit info:
        Model: Asus ExpertBook B1400CBA-0711A1235U
        S/N: R6NXNZ006657238
        CN: 7F6F
        Mainboard Code: B1500CBA R2.1...
        08-16-2025, 12:20 PM
