Remove_SMM... UEFI.
  • sjuric
    • Mar 2013
    • 89232657555
    #161
    I have a problem with the x250
    Problem with locked bios (supervisor password)
    i have Read the file using raspbery pi b+, modified the .bin file, but when i power on the laptop says f1 to go to bios, if i press it the laptop shuts down.
    I have tried multiple times still after pressing f1 the laptop shuts down, havent tried yet reflashing the original bios to it. but i believe nothing's wrong with it.
    the file.
    In the configuration i have replaced the following using UEFITool :
    LenovoTranslateService.fbd
    BootOption.fbd
    SystemPpisNeededByDxeCore.fbd
    this is the original read
    and this is the patched one
    If someone can help with this ill be more than gratefull
    And if someone needs any help with configuring the raspbery feel free to contact me
    internetpharmacydir.com
    • krykot
      • Feb 2019
      • Wroclaw
      #162
      Re: Remove_SMM... UEFI.
      Hello, can anyone help me unlock my lenovo t440?
      This is my original bios dump.
      I have exchanged three files with uefitool:
      BootOption.fbd
      The laptop, after replace these files, starts up but makes 5 sounds, pause and 5 sounds. When I pressed f1 it turns off.
      Thank you very much.
      • krykot
        • Feb 2019
        • Wroclaw
        #163
        BootOption.fbd
        In reference to the post above
        This is patched one:
        Thank you.
        • smok92
          • Oct 2015
          • 27
          • Polnad
          #164
          Insert locked HDD
          • aliencillo
            • Oct 2019
            • 6
            • SPAIN
            #165
            I have finally received my eeprom programmer, and ... successfully achieved! password deleted on my x250, thanks to all who have helped
            • aliencillo
              • Oct 2019
              • 6
              • SPAIN
              #166
              Originally posted by RethoricalCheese
              For that model you might need different file. I am not sure because I haven't compared 4th/5th gen to 6th/7th/8th gen yet. But try it first and let me know.
              Don't forget BootOptions and SystemPpisNeededByDxe which are found in some previous post in this topic.
              it works perfectly
              • alucard6666
                • Aug 2019
                • 24
                • RU
                #167
                5 beeps two time - its a normal?
                • aliencillo
                  • Oct 2019
                  • 6
                  • SPAIN
                  #168
                  Yes, as long continues to the password pront, with the latest BIOS will always give checksum error ( 5 beeps x 2 ), If it ends up working then you have to put your original bios.
                  • alucard6666
                    • Aug 2019
                    • 24
                    • RU
                    #169
                    Laptop freeze, no "press space" message after enter key.
                    • fire1234
                      • Dec 2017
                      • 77
                      • Poland
                      #170
                      if there is no picture, the button marked in red must be pressed
                      • alucard6666
                        • Aug 2019
                        • 24
                        • RU
                        #171
                        image size is 8mb, but t440s need 16mb image.
                        • fire1234
                          • Dec 2017
                          • 77
                          • Poland
                          #172
                          is 16mb, bios tested and must work
                          • alucard6666
                            • Aug 2019
                            • 24
                            • RU
                            #173
                            Its working!! Thank you so much!
                            • alucard6666
                              • Aug 2019
                              • 24
                              • RU
                              #174
                              But this BIOS with clean ME work only for one laptop, other laptop freeze after thinkpad logo. When I press F1 key nothing happens, and laptop freeze.
                              • opus506
                                • Mar 2016
                                • 10
                                I've been trying to make this work for my e580, but I don't think I understand things correctly. Can someone patch my bios for me? Please.
                                • opus506
                                  • Mar 2016
                                  • 10
                                  I had someone help me with the supervisor password for a T450s previously. The patched bios used the allservice program, but its special in that it effectively nulls the hardware ID mechanism.
                                  I think this might be what some of you are looking for, no?
                                  • simpleway
                                    • Feb 2016
                                    • 22
                                    • algerie
                                    #177
                                    Are there a patch for my lenovo x270 6th generation
                                    • simpleway
                                      • Feb 2016
                                      • 22
                                      • algerie
                                      #178
                                      or how i can patch it,
                                      This us thé dump
                                      • przemek_79
                                        • Dec 2014
                                        • 28
                                        • Poland
                                        #179
                                        Hi
                                        Please help to patch bios Lenovo X260
                                        • dani981
                                          • Mar 2018
                                          • 89
                                          • Hungary
                                          #180
                                          Originally posted by przemek_79
                                          Hi
                                          please give me feedback
                                          • DynaxSC
                                            Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
                                            by DynaxSC
                                            Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
                                            For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
                                            06-10-2023, 11:30 AM
                                          • m3vuv
                                            getting an hp elitebook 8730w to work with a gpt drive with uefi
                                            by m3vuv
                                            Its a bit of a long tale but i swapped the original hd for a 2tb ssd,i want about 6 bootable partitions,it needs the uefi enabling in the bios,I am ok with that,the issue is i cant convert the drive to gpt when it has data on it,the issue is windows wont install to a gpt drive,there is a utility from hp to install the efi partition on the drive but it runs on windows,its a chicken and egg thing,can anyone explaine how hp did this?,I am pulling my hair out;it seems i need to run the hp uefi tool to make the uefi option work in the bios, but it needs windows to run this that wont install on a gpt...
                                            07-15-2024, 10:15 AM
                                          • CronaxFD
                                            Is unlocking UEFI worth the hassle? (Surface Pro 4)
                                            by CronaxFD
                                            Hey guys,
                                            Bought myself Surface Pro 4 tablet today on a local craigslist-type website.
                                            I've seen that UEFI was password protected and of course the seller forgot the password, but decided to buy it anyway.
                                            Really needed such a tablet to use with RomRaider to do some logging/tuning on my car.
                                            It has secure boot turned off and boots from USB, so I've formatted SSD and have done clean win10 install.
                                            Works fine, but wanted to ask, are there any real security risks associated with UEFI settings on Surface (remote access etc.)?
                                            From what I've...
                                            03-14-2024, 12:42 PM
                                          • S70rm7r00p3r
                                            Intel NUC NUC6i3SYH UEFI Update went wrong
                                            by S70rm7r00p3r
                                            Hi guys.
                                            I am very new to this business and i have some questions. Maybe someone can help me further.
                                            I have a 2015 Intel NUC NUC6i3SYH and for some internet and office the computer works perfectly. Lately it has been bugging me a bit on and off. Then I saw there is a UEFI update from Intel and I thought if I put it on, the problems might be gone, but unfortunately the update didn't go through. The screen stayed black and after waiting for a while nothing happened, I had to pull the plug at some point. Of course, the NUC then failed to boot!
                                            03-19-2022, 08:59 AM
                                          • hexdy
                                            Modify BIOS to non-uefi
                                            by hexdy
                                            Hello, I wanted to know if it is possible to modify a BIOS file to accept a legacy disk when it does not have the capability, I had this problem on a Optiplex 3060 that were donated to my job where we use non-uefi linux distros, we cannot use uefi since is a "big machine" with this systems beign the center of all of it, we can't change the distro now, maybe make some changes, but if I can modify the BIOS it would be awesome.
                                            05-14-2024, 10:31 AM
