Remove_SMM... UEFI.
  • RethoricalCheese
    • Mar 2013
    • 1517
    • Estonia
    #121
    Re: Remove_SMM... UEFI.
    Originally posted by kiknusko
    I think i find the spot you mentioned about, i changed jmp short loc_64D to short loc_64F
    Yup, exactly what I meant.
    • benderc
      • Oct 2019
      • Norway
      #122
      I Can unlock your ntb for free send me your BIOS dump and model
      Fairly new here, but I'm also interested in this if you are willing to help me
      I got an T480s that Lenovo sent out as a replacement for an old T460s that died and the T480s came with a supervisor password from the refurbishing center in China.
      • kiknusko
        kiknusko
        • Jan 2019
        • 26
        • Slovensko
        #123
        Try this https://www.mediafire.com/file/1nh0u...TCH_9.BIN/file
        • benderc
          • Oct 2019
          • Norway
          #124
          Thanks! I will give it a go later tonight and report back
          • RethoricalCheese
            • Mar 2013
            • 1517
            • Estonia
            #125
            Better upload your bios dump. Got to modify that file.
            • benderc
              • Oct 2019
              • Norway
              #126
              Ok, here is my original dump:
              https://www.mediafire.com/file/7rdx2...s-org.zip/file
              • aliencillo
                • Oct 2019
                • 6
                • SPAIN
                #127
                Hi, can I have the modified lenovotranslateservice?
                I prefer to cook my bios and learn something
                thanks
                • RethoricalCheese
                  • Mar 2013
                  • 1517
                  • Estonia
                  #128
                  So this is the LenovoTranslateService file I patched so it would accept any key.
                  I did test it on X260 and it did work well. But when I tested it on X270, there would be beeps but no display.
                  I know that 6th, 7th and 8th gen share the same LenovoTranslateService and BootOptions file (I compared patched files for different models). There may be another file needed ?!
                  • aliencillo
                    • Oct 2019
                    • 6
                    • SPAIN
                    #129
                    Thx
                    I will try it on my x250 when I receive my new programmer..
                    • RethoricalCheese
                      • Mar 2013
                      • 1517
                      • Estonia
                      #130
                      Originally posted by aliencillo
                      Thx
                      For that model you might need different file. I am not sure because I haven't compared 4th/5th gen to 6th/7th/8th gen yet. But try it first and let me know.
                      Don't forget BootOptions and SystemPpisNeededByDxe which are found in some previous post in this topic.
                      • imranromi
                        • Jan 2015
                        • 1288
                        • Pakistan
                        #131
                        What purpose this file SystemPpisNeededByDxe?
                        • RethoricalCheese
                          • Mar 2013
                          • 1517
                          • Estonia
                          #132
                          Well, good point. If uefitool is used then it is actually not needed because when BootOption is replaced in Uefitool, SystemPpisNeededByDxe gets modified automatically anyway.
                          • imranromi
                            • Jan 2015
                            • 1288
                            • Pakistan
                            #133
                            Yes this is my point you understand well..
                            Or give me email i have some info about toshiba i know you interested this topic or i not have option i contact pm or email.
                            my email:*********************
                              • 20674
                              The last 3 posts about Toshibas have been deleted,they`re all off topic and not related to this thread.
                              Start a new thread.
                              • BIOSG3tta3
                                • Mar 2019
                                • 11
                                @RethoricalCheese - Do you know if your patched file works on both 7 and 9 digit ID's, or does that not matter and as long as file is compatible with system it should work?
                                I don't need right now, can't test, only following along to try and learn and or help, to be able to sort this out for others later who need unlocked.
                                What you did was my first thought too, jump different or bypass area, before it was mentioned on page 1 post #11 - good to see that was a good idea and it's now proven working method at least on some systems.
                                I guess from my end, it doesn't help that I'm not familiar with these models or what generation is what
                                We need to put together a package of files xx1 set for xxgen1/models and then another for xx2 set for xxgen2/models.
                                If you need help trying to figure out how to patch anything let me know, I am good at than kind of thing too, but do not own any of these systems (only help people with BIOS often)
                                • coumcoum
                                  • Dec 2015
                                  • 36
                                  • algerie
                                  #136
                                  hello
                                  i have T480s i need help for unlock
                                  thanks
                                  • dwirachmat
                                    • Sep 2015
                                    • 7
                                    • indonesia
                                    #137
                                    I use that file to patch bios on x250, but it still need 7 digit key. Input any key, it will say invalid.
                                    • RethoricalCheese
                                      • Mar 2013
                                      • 1517
                                      • Estonia
                                      #138
                                      BIOSG3tta3, it doesn't matter which one.
                                      dwirachmat, yes it will ask for key but it accepts any key. And yes, it will say invalid but it continues to the valid part right after that. Did you replace BOTH files or just LenovoTranslateService?
                                      • BIOSG3tta3
                                        • Mar 2019
                                        • 11
                                        Thanks, good to know!
                                        • dwirachmat
                                          • Sep 2015
                                          • 7
                                          • indonesia
                                          #140
                                          just BootOption and your LenovoTranslateService patch. but when i fill any key and press enter, it just stuck on invalid key. not continue like when i fill correct key that someone gave to me. when correct it will be ask me to press space twice.
                                          so maybe when it stuck on invalid key, i must shut it down and reflash with original bios right? or how?
                                          • DynaxSC
                                            Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
                                            by DynaxSC
                                            Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
                                            For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
                                            06-10-2023, 11:30 AM
                                          • m3vuv
                                            getting an hp elitebook 8730w to work with a gpt drive with uefi
                                            by m3vuv
                                            Its a bit of a long tale but i swapped the original hd for a 2tb ssd,i want about 6 bootable partitions,it needs the uefi enabling in the bios,I am ok with that,the issue is i cant convert the drive to gpt when it has data on it,the issue is windows wont install to a gpt drive,there is a utility from hp to install the efi partition on the drive but it runs on windows,its a chicken and egg thing,can anyone explaine how hp did this?,I am pulling my hair out;it seems i need to run the hp uefi tool to make the uefi option work in the bios, but it needs windows to run this that wont install on a gpt...
                                            07-15-2024, 10:15 AM
                                          • CronaxFD
                                            Is unlocking UEFI worth the hassle? (Surface Pro 4)
                                            by CronaxFD
                                            Hey guys,
                                            Bought myself Surface Pro 4 tablet today on a local craigslist-type website.
                                            I've seen that UEFI was password protected and of course the seller forgot the password, but decided to buy it anyway.
                                            Really needed such a tablet to use with RomRaider to do some logging/tuning on my car.
                                            It has secure boot turned off and boots from USB, so I've formatted SSD and have done clean win10 install.
                                            Works fine, but wanted to ask, are there any real security risks associated with UEFI settings on Surface (remote access etc.)?
                                            From what I've...
                                            03-14-2024, 12:42 PM
                                          • S70rm7r00p3r
                                            Intel NUC NUC6i3SYH UEFI Update went wrong
                                            by S70rm7r00p3r
                                            Hi guys.
                                            I am very new to this business and i have some questions. Maybe someone can help me further.
                                            I have a 2015 Intel NUC NUC6i3SYH and for some internet and office the computer works perfectly. Lately it has been bugging me a bit on and off. Then I saw there is a UEFI update from Intel and I thought if I put it on, the problems might be gone, but unfortunately the update didn't go through. The screen stayed black and after waiting for a while nothing happened, I had to pull the plug at some point. Of course, the NUC then failed to boot!
                                            03-19-2022, 08:59 AM
                                          • hinsech475
                                            Fujitsu LIFEBOOK AH562-UEFI problem-Help request
                                            by hinsech475
                                            Hi, I would appreciate your help with the following problem.
                                            I have a Fujitsu laptop AH562 witn a BIOS-UEFI problem since I converted the HDD to a SSD. For more details on the paltop go to the following link:
                                            http://support.fujitsupc.com/CS/Port...srch=TECHSPECS
                                            After copying the HDD to SSD with ALtiris utility provided with the Kingston SSD and replacing the HDD with the SSD the laptop went into a startup loop with no screen display and only the disk LED flashing twice per second. I waited for approximatly 2h and then stopped the laptop...
                                            06-03-2018, 10:57 PM
