Remove_SMM... UEFI.
  • siwykk
    • May 2020
    • 54
    • N/A
    #1621
    Re: Remove_SMM... UEFI.
    Originally posted by sabah
    need patched bios for my thinkpad t480
    Try...
      • 21523
      Try the lenovo Autopatcher
      BIOS guides, methods, resources and tools
      https://www.badcaps.net/forum/showthread.php?t=103526
      • wilkerbhz
        • Jul 2017
        • Brasil
        #1623
        Originally posted by siwykk
        Try...
        My friend worked, thanks a lot for your help.
        • NERI
          • Jun 2016
          • 18
          • slp
          #1624
          buen dia comunidad, tengo un volcado de t490 alguien lo puede parchar o alguna manera para quitar la contraseña de este modelo ...
          Good morning community, I have a t490 dump, can someone patch it or some way to remove the password from this model...
          • miansh621
            Banned
            • May 2022
            • 133
            • pakistan
            #1625
            try
            • greymind
              • Feb 2023
              • 12
              • New Zealand
              #1626
              May I know if this method works for ThinkPad X1 Yoga Gen 5? Thanks.
              • nerubian01
                • Jan 2020
                • Česko
                #1627
                hello
                i patched my orginal bios T460S
                but when i test i have black screen with beep
                • Markus1741
                  • Sep 2020
                  • 883
                  • N/A
                  #1628
                  Originally posted by nerubian01
                  hello
                  I hope you read that carefully, everything should be fine with your BIOS file.
                  I just cleaned the ME region, I don't know if that will help, try it.
                  https://www.badcaps.net/forum/showpo...52&postcount=1
                  Good luck ...
                  • mikay786
                    • Aug 2014
                    • 765
                    Just to clarify to remove bios password from a Lenovo T450
                    I have a Xgecu TL866 II Plus programmer, is this suitable?
                    Need to extract original bios making sure i have a backup and follow the instructions here - https://www.badcaps.net/forum/showpo...52&postcount=1
                    Basically running the patcher at the original bios file, which will make a patched bios file, which you then flash back on to the chip?
                    • Elettrone62
                      • Nov 2021
                      • 7
                      • Italia
                      #1630
                      Originally posted by Smartguru@24
                      Try this new patch method & update me
                      Good day, I'm looking for someone in the forum who can give me information on whether he has managed to remove the password on a T495, from what I see in the messages from SmartGuru@24 and from black0hackers it seems so, I'm asking for your help as by patching the my Bios as indicated in a few previous messages I only get a series of sounds the black screen and the cpu fan that spins for a few seconds then stops, I also waited a certain time by pressing keys but no none. Thank you
                      • Elettrone62
                        • Nov 2021
                        • 7
                        • Italia
                        #1631
                        In addition to my message, I also attach the original file and the Patch one I got, but with this I get that it doesn't work by reprogramming the eprom with the original BIOS, it works as before, protected by password. It is a Lenovo T495 version 20NK. I performed the operations with the main battery and backup battery disconnected.
                        • Elettrone62
                          • Nov 2021
                          • 7
                          • Italia
                          #1632
                          In addition to what is written, the T495 is equipped with an AMD Ryzen Pro 3500U
                          • Alexkr
                            • Dec 2022
                            • Россия
                            #1633
                            Hello! Can you help me please.
                            thinkpad a275 not working after trying to reset bios.
                            Black screen.
                            I found a clean firmware on the forum. Clear.
                            After starting the laptop - the Lenovo logo and reboot again.
                            When pressing Enter - Error 0183: Bad CRC of Security Security Settings in EFI variable.
                            I press F1 - and the computer restarts again.
                            I have a backup of the old bios - but it doesn't work.
                            Can you see what happened to the old backup? Or somehow transfer the data from the old backup to a clear one? I could only find the Windows serial number.
                            • zinnou
                              • 37
                              • algeria
                              #1634
                              Originally posted by cdma-india
                              thanks all , problem solve
                              hello have samme problem lenovo t440 16mb after writ patch file black scran only any help ??
                              • reassor
                                • Apr 2021
                                • 176
                                • Poland
                                #1635
                                Working - you can all use it on E550
                                • mbusoluju
                                  • Mar 2022
                                  • 21
                                  • Swaziland
                                  #1636
                                  T440S i7 vpro bios patch needed
                                  i need bios patch for lenovo t440s core i7 with vpro. ihave attached the original bios with password.most files not working.
                                    • 21523
                                    Re: T440S i7 vpro bios patch needed
                                    You must post the serial number.You must try the methods already posted in the forum,have you tried the lenovo Autopatcher ?
                                    • Morph.
                                      • Nov 2023
                                      • germany
                                      #1638
                                      Hi Everyone,
                                      i have a Lenovo P15v 1.Gen and i need to start from USB ( a Linux Live ). The Laptop is for my studies and now i cant boot it from other Harddiscs like USB etc.
                                      I have check the Bios Security, but my Finger-Checkup was successful, but the password for Administrator to change the Bios Security Settings was forget ..
                                      So i want first to ask, that the autopatcher can help on a Lenovo P15V?
                                      I dont want to brick my Laptop :-)
                                      Thx for Replay
                                      • DarkMooon
                                        • Apr 2021
                                        • 11
                                        • UA
                                        #1639
                                        hello
                                        lpm-1 mb 17870-1 ( mec1653 )
                                        i tried autopatcher not success just Melody beeping
                                        used the evsa patch as instructed : https://www.badcaps.net/forum/showpo...&postcount=482
                                        TCPABIOS is missing
                                        i need to remove password
                                        or maybe someone has the full mec1653 firmware with the boot region
                                        sn: R90RCF5J
                                        • Maxpower3
                                          Bad Veteran
                                          • Feb 2018
                                          • 1274
                                          • France
                                          #1640
                                          Originally posted by DarkMooon
                                          hello
                                          TCPABIOS is missing
                                          i need no clean password
                                          serial number
                                          • DynaxSC
                                            Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
                                            by DynaxSC
                                            Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
                                            For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
                                            06-10-2023, 11:30 AM
                                          • m3vuv
                                            getting an hp elitebook 8730w to work with a gpt drive with uefi
                                            by m3vuv
                                            Its a bit of a long tale but i swapped the original hd for a 2tb ssd,i want about 6 bootable partitions,it needs the uefi enabling in the bios,I am ok with that,the issue is i cant convert the drive to gpt when it has data on it,the issue is windows wont install to a gpt drive,there is a utility from hp to install the efi partition on the drive but it runs on windows,its a chicken and egg thing,can anyone explaine how hp did this?,I am pulling my hair out;it seems i need to run the hp uefi tool to make the uefi option work in the bios, but it needs windows to run this that wont install on a gpt...
                                            07-15-2024, 10:15 AM
                                          • CronaxFD
                                            Is unlocking UEFI worth the hassle? (Surface Pro 4)
                                            by CronaxFD
                                            Hey guys,
                                            Bought myself Surface Pro 4 tablet today on a local craigslist-type website.
                                            I've seen that UEFI was password protected and of course the seller forgot the password, but decided to buy it anyway.
                                            Really needed such a tablet to use with RomRaider to do some logging/tuning on my car.
                                            It has secure boot turned off and boots from USB, so I've formatted SSD and have done clean win10 install.
                                            Works fine, but wanted to ask, are there any real security risks associated with UEFI settings on Surface (remote access etc.)?
                                            From what I've...
                                            03-14-2024, 12:42 PM
                                          • S70rm7r00p3r
                                            Intel NUC NUC6i3SYH UEFI Update went wrong
                                            by S70rm7r00p3r
                                            Hi guys.
                                            I am very new to this business and i have some questions. Maybe someone can help me further.
                                            I have a 2015 Intel NUC NUC6i3SYH and for some internet and office the computer works perfectly. Lately it has been bugging me a bit on and off. Then I saw there is a UEFI update from Intel and I thought if I put it on, the problems might be gone, but unfortunately the update didn't go through. The screen stayed black and after waiting for a while nothing happened, I had to pull the plug at some point. Of course, the NUC then failed to boot!
                                            03-19-2022, 08:59 AM
                                          • hexdy
                                            Modify BIOS to non-uefi
                                            by hexdy
                                            Hello, I wanted to know if it is possible to modify a BIOS file to accept a legacy disk when it does not have the capability, I had this problem on a Optiplex 3060 that were donated to my job where we use non-uefi linux distros, we cannot use uefi since is a "big machine" with this systems beign the center of all of it, we can't change the distro now, maybe make some changes, but if I can modify the BIOS it would be awesome.
                                            05-14-2024, 10:31 AM
