Remove_SMM... UEFI.
  • jebaniutki
    • Nov 2020
    • Bolanda
    #1261
    Re: Remove_SMM... UEFI.
    Originally posted by Maxpower3
    Ok I understand your opinion.
    So for beginners, I made this new version which is easier to use.
    Only for Windows.
    Just install LENOVO DXE Auto-Patcher.exe
    And Click on desktop shortcut.
    Need Python 2.7.X
    Ps:"there is no interface for the moment, I have to finish the multi bios Patcher for that"
    For Windows 7 and 10 , 32b or 64b
    -------- Auto patcher with file selection V2 Version Mxp -------
    Special thanks to Knucklegrumble
    -Version Mxp:
    - Possibility to select your file directly
    - Auto-install with shortcut on desktop
    - Possibility of making several files in succession
    - With additionnal splashscreen
    Tested with version python 2.7
    Tested ok on W10 and Win 7(VM)
    Enjoy ,Test and Report please
    This tool don't work properly on Win7.
    Script doing step 1/2 and end. I can see in orginal dump file folder created "patched" file, but it's deleted when script trying doing step 2/2.
    Version started in cmd way, work properly and create "patched" file.
    • LatinMcG
      • Jun 2015
      • 73
      • USA/Puerto Rico
      #1262
      i got a T495 that fails patching the fvNVRAm with hash mismatch.
      i manually added the fvnvram.vol to it in hexedit and patched.. havent tested it yet.
      • LatinMcG
        • Jun 2015
        • 73
        • USA/Puerto Rico
        #1263
        no video with hash mismatch file.
        with original file it boots to pwd screen but not the bypass.
        seems the nvram is slightly different at offset 80000
        ìs�EVSA
        i attach original crazy beep song bin but i think it was messed with prior to me.
        • Markus1741
          • Sep 2020
          • 882
          • N/A
          #1264
          Maybe someone can help me.
          I have a Lenovo T550 with a Macronix MX25L12873L BIOS chip.
          I created a BIOS dump using autopatcher.
          Reading, writing, no problem.
          When I start the notebook I hear 5x beeps 5x beeps and only see "to interrupt normal startup press enter" that was it. Enter does not work.
          Maybe someone can edit the original dump to make it work.
          The same Lenovo T550 with Winbond chip is no problem.
          Here is the original dump.
          Many Thanks
          • btoska
            • Jul 2011
            • 5
            #1265
            i try to patched now bios only beep can clear my dump please
            • Markus1741
              • Sep 2020
              • 882
              • N/A
              #1266
              Hi try this!
              • datodati962@gmail.com
                • May 2020
                • 48
                • alb
                #1267
                please need to patch lenovo x240 please
                • Markus1741
                  • Sep 2020
                  • 882
                  • N/A
                  #1268
                  Good luck!
                  • ibo
                    • Oct 2019
                    • 94
                    • Turkiye
                    #1269
                    Hi there,
                    is there any solution for T490S Bios password?
                    • AAAC
                      • Jan 2020
                      • 458
                      • Mexico
                      #1270
                      @ibo
                      Yes, the solution is to use a EC/KBC programmer.
                      • ibo
                        • Oct 2019
                        • 94
                        • Turkiye
                        #1271
                        Originally posted by AAAC
                        @ibo
                        Can you tell me more how to do? and wich programmer i need?
                        • hsch_dk
                          • Feb 2020
                          • Denmark
                          #1272
                          Hi All!
                          First of all, thanks for a great forum, I get loads of inspiration, an learn so much (and spend way to much time in here :-))
                          I have been playing around with this tool: https://www.badcaps.net/forum/showthread.php?t=87588
                          one thing I cant figure our is why it is that the output file being automatic deleted after the successfully run - I can see it being created in the right folder, but when done it disappears - anyone who has views on what I should do?
                          thanks!
                          • zyfang
                            • Dec 2020
                            • Philippines
                            #1273
                            hi guys, need help on this bios. thanks in advance
                            • zyfang
                              • Dec 2020
                              • Philippines
                              #1274
                              how to attach may bios here? sorry for noob Question.
                              • Motherboard Repairs
                                • May 2019
                                • 63
                                #1275
                                Hello
                                Anyone out here cracked Lenovo P52 (20MA-S58B00) already tried AutoPatch and LenovoTranslateService, BootOptions method.
                                Here is my dump give it a try .
                                  • May 2020
                                  • 48
                                  • alb
                                  #1276
                                  thankyou!
                                    • May 2019
                                    • 63
                                    #1277
                                    Originally posted by Motherboard Repairs
                                    Hello
                                    Updated, i have managed to remove the password thanks to Esmat. If i had more time most likely I would of cracked it due to client not being patient.
                                    Be aware of a seller on ebay username ********** i was going to make purchase to remove the bios when he realised i posted on badcaps his price changed and asked double to what he has listed on ebay. Clearly his listing states P52 supported made excuses such as it has to be 2018 mine is .
                                    • Ghamidi
                                      • Mar 2020
                                      • 305
                                      • France
                                      #1278
                                      Be aware of a seller on ebay username *********** i was going to make purchase to remove the bios when he realised i posted on badcaps his price changed and asked double to what he has listed on ebay. Clearly his listing states P52 supported made excuses such as it has to be 2018 mine is .
                                      Hello;
                                      please can you upload patched bios
                                      thank you
                                      • Karol
                                        • May 2016
                                        • 89
                                        #1279
                                        Posting rules:
                                        5) Keep things civil! There will be no tolerance for flaming, bashing, hateful remarks, racial remarks, porn of ANY kind, and so on.
                                        I can send in private to admin all conversation with "Motherboard Repairs"
                                        Just let me know.
                                        Thank You !
                                        Joe's KMX1 Pro S, RevelprogIS, TL866II, CH341A, Vertyanov JIG 3.1, Eakins Microscope, Gordak 952, 30V/5Ah PSU, 890C+, T2L Thermal Camera, SVOD 3, etc.
                                        • t-boy09
                                          • Jun 2019
                                          • 5
                                          • South Africa
                                          #1280
                                          Could some one help me with L480 bios patched without password?
                                          • DynaxSC
                                            Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
                                            by DynaxSC
                                            Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
                                            For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
                                            06-10-2023, 11:30 AM
                                          • m3vuv
                                            getting an hp elitebook 8730w to work with a gpt drive with uefi
                                            by m3vuv
                                            Its a bit of a long tale but i swapped the original hd for a 2tb ssd,i want about 6 bootable partitions,it needs the uefi enabling in the bios,I am ok with that,the issue is i cant convert the drive to gpt when it has data on it,the issue is windows wont install to a gpt drive,there is a utility from hp to install the efi partition on the drive but it runs on windows,its a chicken and egg thing,can anyone explaine how hp did this?,I am pulling my hair out;it seems i need to run the hp uefi tool to make the uefi option work in the bios, but it needs windows to run this that wont install on a gpt...
                                            07-15-2024, 10:15 AM
                                          • CronaxFD
                                            Is unlocking UEFI worth the hassle? (Surface Pro 4)
                                            by CronaxFD
                                            Hey guys,
                                            Bought myself Surface Pro 4 tablet today on a local craigslist-type website.
                                            I've seen that UEFI was password protected and of course the seller forgot the password, but decided to buy it anyway.
                                            Really needed such a tablet to use with RomRaider to do some logging/tuning on my car.
                                            It has secure boot turned off and boots from USB, so I've formatted SSD and have done clean win10 install.
                                            Works fine, but wanted to ask, are there any real security risks associated with UEFI settings on Surface (remote access etc.)?
                                            From what I've...
                                            03-14-2024, 12:42 PM
                                          • S70rm7r00p3r
                                            Intel NUC NUC6i3SYH UEFI Update went wrong
                                            by S70rm7r00p3r
                                            Hi guys.
                                            I am very new to this business and i have some questions. Maybe someone can help me further.
                                            I have a 2015 Intel NUC NUC6i3SYH and for some internet and office the computer works perfectly. Lately it has been bugging me a bit on and off. Then I saw there is a UEFI update from Intel and I thought if I put it on, the problems might be gone, but unfortunately the update didn't go through. The screen stayed black and after waiting for a while nothing happened, I had to pull the plug at some point. Of course, the NUC then failed to boot!
                                            03-19-2022, 08:59 AM
                                          • hexdy
                                            Modify BIOS to non-uefi
                                            by hexdy
                                            Hello, I wanted to know if it is possible to modify a BIOS file to accept a legacy disk when it does not have the capability, I had this problem on a Optiplex 3060 that were donated to my job where we use non-uefi linux distros, we cannot use uefi since is a "big machine" with this systems beign the center of all of it, we can't change the distro now, maybe make some changes, but if I can modify the BIOS it would be awesome.
                                            05-14-2024, 10:31 AM
