Remove_SMM... UEFI.
  • JOHNLAG7
    • Nov 2014
    • 19
    • Greece
    #1061
    Re: Remove_SMM... UEFI.
    Many thanks all done ok confirm that works on x1 6th
    • datodati962@gmail.com
      • May 2020
      • 48
      • alb
      #1062
      Hello Folk,please need help to remove password think pad youga X1 firt generation.
      thanks.
      • Knucklegrumble
        • Jun 2020
        • 78
        • US
        #1063
        thanks.
        Use the auto-patcher. Read the instructions and report the results.
        https://www.badcaps.net/forum/showthread.php?t=87588
        Thanks.
        • Ghamidi
          • Mar 2020
          • 305
          • France
          #1064
          thanks.
          try this file
            • May 2020
            • 48
            • alb
            #1065
            Thanks it's work!
              • May 2020
              • 48
              • alb
              #1066
              Anyone can be more specific how to use autopatch,any photo step by step or any video tutorial?Tanks
                • 21523
                The instructions are simple enough,why do you need step by step photos.
                  • May 2020
                  • 48
                  • alb
                  #1068
                  Couse I can't open autopatch.cmd
                    • 21523
                    The instructions say you have to run autopatch.cmd from the command line,if you`re using windows.
                      • May 2020
                      • 48
                      • alb
                      #1070
                        • May 2020
                        • 48
                        • alb
                        #1071
                        I try to open with run administrator CMD and can't be open autopatch.cmd
                          • 21523
                          Open the command line and navigate to the directory where your auto_patcher folder is.For example,if you have it on your C drive
                          cd c:\lenovo_autopatcher
                          autopatch.cmd
                            • May 2020
                            • 48
                            • alb
                            #1073
                            In that way I try. Open command line administratior cd.. cd..
                            Then I copy link from folder press enter and i'm inside directory,insert autopatch.cmd press enter then nothing happens.what other I can do after I all command I insert? Then I need to insert bios bin from CMD or what?
                              • May 2020
                              • 48
                              • alb
                              #1074
                              Ok I done,I understand what's the way.
                              Thank you
                              • Knucklegrumble
                                • Jun 2020
                                • 78
                                • US
                                #1075
                                Thank you
                                autopatch.cmd path\to\bios.bin
                                • Maxpower3
                                  Bad Veteran
                                  • Feb 2018
                                  • 1274
                                  • France
                                  #1076
                                  hi,
                                  why don't you integrate the Bios selection that I added? it's much easier to choose your file.
                                  Thanks again for your patch
                                  • Ghamidi
                                    • Mar 2020
                                    • 305
                                    • France
                                    #1077
                                    Originally posted by Maxpower3
                                    hi,
                                    THANK YOU FRIEND
                                    I WAITING FOR U BIOS MULTITOOLS
                                    • Knucklegrumble
                                      • Jun 2020
                                      • 78
                                      • US
                                      #1078
                                      hi,
                                      Because it only works on windows. I want the auto-patcher to work consistently across windows and Linux. Also leaving it more "lean" allows for easier integration with others tools (like you did).
                                      You guys are welcome to modify the base script as you see fit to make it more convenient for you to use.
                                      • Ghamidi
                                        • Mar 2020
                                        • 305
                                        • France
                                        #1079
                                        Originally posted by knucklegrumble
                                        because it only works on windows. I want the auto-patcher to work consistently across windows and linux. Also leaving it more "lean" allows for easier integration with others tools (like you did).
                                        thank you bro for your great job
                                        • Maxpower3
                                          Bad Veteran
                                          • Feb 2018
                                          • 1274
                                          • France
                                          #1080
                                          Ok I understand your opinion.
                                          So for beginners, I made this new version which is easier to use.
                                          Only for Windows.
                                          Just install LENOVO DXE Auto-Patcher.exe
                                          And Click on desktop shortcut.
                                          Need Python 2.7.X
                                          Ps:"there is no interface for the moment, I have to finish the multi bios Patcher for that"
                                          For Windows 7 and 10 , 32b or 64b
                                          -------- Auto patcher with file selection V2 Version Mxp -------
                                          Special thanks to Knucklegrumble
                                          -Version Mxp:
                                          - Possibility to select your file directly
                                          - Auto-install with shortcut on desktop
                                          - Possibility of making several files in succession
                                          - With additionnal splashscreen
                                          Tested with version python 2.7
                                          Tested ok on W10 and Win 7(VM)
                                          Enjoy ,Test and Report please
                                          • DynaxSC
                                            Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
                                            by DynaxSC
                                            Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
                                            For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
                                            06-10-2023, 11:30 AM
                                          • m3vuv
                                            getting an hp elitebook 8730w to work with a gpt drive with uefi
                                            by m3vuv
                                            Its a bit of a long tale but i swapped the original hd for a 2tb ssd,i want about 6 bootable partitions,it needs the uefi enabling in the bios,I am ok with that,the issue is i cant convert the drive to gpt when it has data on it,the issue is windows wont install to a gpt drive,there is a utility from hp to install the efi partition on the drive but it runs on windows,its a chicken and egg thing,can anyone explaine how hp did this?,I am pulling my hair out;it seems i need to run the hp uefi tool to make the uefi option work in the bios, but it needs windows to run this that wont install on a gpt...
                                            07-15-2024, 10:15 AM
                                          • CronaxFD
                                            Is unlocking UEFI worth the hassle? (Surface Pro 4)
                                            by CronaxFD
                                            Hey guys,
                                            Bought myself Surface Pro 4 tablet today on a local craigslist-type website.
                                            I've seen that UEFI was password protected and of course the seller forgot the password, but decided to buy it anyway.
                                            Really needed such a tablet to use with RomRaider to do some logging/tuning on my car.
                                            It has secure boot turned off and boots from USB, so I've formatted SSD and have done clean win10 install.
                                            Works fine, but wanted to ask, are there any real security risks associated with UEFI settings on Surface (remote access etc.)?
                                            From what I've...
                                            03-14-2024, 12:42 PM
                                          • S70rm7r00p3r
                                            Intel NUC NUC6i3SYH UEFI Update went wrong
                                            by S70rm7r00p3r
                                            Hi guys.
                                            I am very new to this business and i have some questions. Maybe someone can help me further.
                                            I have a 2015 Intel NUC NUC6i3SYH and for some internet and office the computer works perfectly. Lately it has been bugging me a bit on and off. Then I saw there is a UEFI update from Intel and I thought if I put it on, the problems might be gone, but unfortunately the update didn't go through. The screen stayed black and after waiting for a while nothing happened, I had to pull the plug at some point. Of course, the NUC then failed to boot!
                                            03-19-2022, 08:59 AM
                                          • hexdy
                                            Modify BIOS to non-uefi
                                            by hexdy
                                            Hello, I wanted to know if it is possible to modify a BIOS file to accept a legacy disk when it does not have the capability, I had this problem on a Optiplex 3060 that were donated to my job where we use non-uefi linux distros, we cannot use uefi since is a "big machine" with this systems beign the center of all of it, we can't change the distro now, maybe make some changes, but if I can modify the BIOS it would be awesome.
                                            05-14-2024, 10:31 AM
