Asus x45a bios dump
  • Levi
    • May 2014
    • 59
    • Ghana
    Asus x45a bios dump
    Asus x45a bios dump needed urgently
  • cacla
    • Apr 2015
    • 442
    Re: Asus x45a bios dump
    Try this one
    • Levi
      • May 2014
      • 59
      • Ghana
      thanks, will give you update
      • kodox
        • Jul 2017
        • 322
        • Indonesia
        Originally posted by cacla
        Try this one
        thank's man, it's work!!!!
        i thought it was vrm chip broken, because there was no voltage generated on GFX_CORE
        • amozc
          • Jun 2016
          • indonesia
          Ijin gan
          • gigimacan
            • Dec 2017
            • indonesia
            asus x45a clear me please?
            • qayyum786
              • Aug 2018
              • 1933
              • INDIA
              Post your backup
              • razor_amd
                by razor_amd
                12-15-2020, 07:07 PM
              • DynaxSC
                by DynaxSC
                06-14-2024, 03:49 PM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
              • Habble7
                by Habble7
                Suspected Cause:
                Troubleshooting Attempts:
                05-22-2025, 07:28 AM
              • Anchar777
                ASUS P1412CE need BIOS DUMP
                by Anchar777
                Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
                06-26-2025, 03:39 AM
