need bios dump (EC+MAIN ) of toshiba C55-B1336
    hello everybody,
    I need the bios dump (EC+MAIN ) of toshiba C55-B1336, motherboad number:
    DA0BLKMB6E0 REV: E
    PSKTWV-02D00MA3
    Re: need bios dump (EC+MAIN ) of toshiba C55-B1336
    Backup and try. Confirm results.
      Thanks for your answer but unfortunately the same State...
      Please give me important signals to measure tham
      right Now ihave:
      vin:19v
      +3VPCU +5VPCU in stepdown section
      Pin8 of bios: 0v
      RSMRST: 0V
      if you have schematic for this board please give it to me....
        i think schematic not available for this model
          Is the mb switching?? If so, then measure voltages at all coils first and report. There are lot of experienced members here who can help.
            Thank you mcplslg123 very much
              Vin in SIO:
              EC:
              PIN1,PIN2,PIN3,PIN4,PIN7:0V (GND)
              PIN5,PIN6,PIN8:3.3V
              BIOS:
              ALL PIN : 0V
              Please Help me.... WHAT CAN I DO..
                It seems you have 3VALW And 5VALW at coil. 3V AALW should go to sio and from there you should get 3v at power button. Check SIO for corrosion,shorting or any componenets which looks suspect. Check 3 & 5v SUS voltage
                  SIO is getting 3VALW but One of SIO vin pin 88 there is no voltage Normly we get 3.3v there
                  and this pin is directly related with pin 8 of bios chip and other comp.
                  maybe there is a short
                  the resistance of this pin i get 10 ohm
                  3 & 5v SUS voltage available in the tow mosfet
                    Please guide me...
                      Where are you please help
                        Did you check pin 88 of SIO chips has continuity with other pins or 3VPCU_EC line?
                        Maybe line of 3VPCU was broke inside layer of PCB.
                        Did you measure resistance with plugged adapter? if pin 88 have connect to pin 19, 46, etc, could be the IC (RT6575A) get warm or hot
                        - Only one of 3 ICs (RT8068AZQW, with mark 13, PU4, PU5 and PU6) should be have voltage 1.8VPCU. Read schematic Quanta ZHK or ZQM. Easy to finding on google or s-manual
                        - I don't see IC charge pump (G5934RZ1U) for load switch, maybe only use double of Diode as charge pump.
                        - Link image:
                        https://www.mediafire.com/folder/fh9...BLKMB6E0_Rev.E)
                          Thank you very much, man for helping me with everything clear I will measure...right Now
                          to be continued... thank you agane
                            After a lot of test this is result:
                            I measured resistance with plugged adapter pin 88 with 16.46.... i get 52.5OHM
                            Voltage Existe:
                            +3VPCU
                            +5VPCU
                            +5VS5
                            Voltage NO Existe:
                            +1.8VPCU
                            +3VS5
                            *** And i get S5_ON VOLTAGE IS: 2.56V Is it normale
                              i need tihs bios c55-c2045 (DABLQMB16B0 REV.B) plz
                                Please i need bios+EC ...
                                Toshiba Satellite C55-B1325
                                da0blkmb6e0 rev: e
                                will be thanking ..
