Asus X550LB power on then off fixed.Working dump
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Had this laptop, X550LB, Core i7, nVidia GT740m. It powered on then back off. No short. Remove CMOS battery and it stayed on, but with no display and WLAN led blinking.
    Cause: Corrupted BIOS.
    Attached working dump.
    A working TV? How boring!
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: Asus X550LB power on then off fixed
    thanks for sharing.
    how did the BIOS get Corrupted?
    • vladislav77
      • Jun 2019
      • Russia
      Re: Asus X550LB power on then off fixed.Working dump
      Thank you very much! It's just what I was looking for.
      Notebook was turning on auto-powered and didn't initialize, consuming current about 0,5A statically.
      Power, CapsLock and NumLock LEDs were on.
      With this dump it became alive again!
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        Too little, too late, but don't know, don't care.
        You are experienced enough that you know than when a no power or no picture rolls into the shop fresh with no obvious physical damage, battery missing or good condition and no burns, no smoke, no skid marks, no major electrical shorts, a fresh BIOS flash is the first thing you do.
        • GLISIT
          by GLISIT
          01-16-2025, 02:29 PM
        • PantherDave
          by PantherDave
          Hi all!
          05-29-2024, 02:01 PM
        • ShadowAi
          ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
          by ShadowAi
          Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
          Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
          After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
          03-15-2024, 10:46 AM
        • Andreas_de
          Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
          by Andreas_de
          Hello!
          i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
          Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
          Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
          04-12-2025, 10:38 AM
