I need Lenovo IdeaPad Y500 LA-8692P bios dump
  • ibrahim03
    • Oct 2015
    • 143
    • egypt
    main+ec
    thanks advance
  • ibrahim03
    • Oct 2015
    • 143
    • egypt
    Re: I need Lenovo IdeaPad Y500 LA-8692P bios dump
    up up up
    • sopik78
      • Nov 2013
      • 518
      • Czech Republic
      Try this..
      • kapserajug
        • Nov 2017
        • 84698575461
        thank you sir
        visit cialispascherfr24
        • whitevolf
          • Feb 2014
          • 123
          • TÜRKİYE
          thanks
          • spurki
            • Apr 2020
            • 43
            • romania
            not working
            • bobok19
              • Oct 2023
              • 5
              • Slovakia
              Hello, I am new in this branch of BIOS programming. I have problem with BIOS (probably ME region) on Lenovo Y500, type 9541, LA-8692P. After unsuccessfull BIOS flash using InsydeFlash, the laptop wouldn´t turn on, only fan goes, screen was black. I try to flash BIOS using EZP2023+. I used the BIOS from this post - https://www.badcaps.net/forum/showth...ht=lenovo+y500
              After flash, sometimes the laptop turn on and boot Windows, sometimes the fan spins but the screen is black. When I boot Windows, I try to update BIOS with InsydeFlash, but error occurs - BIOS version compare error.
              I think I need clean ME region, but I do not know how. Please, can me help someone?
              Can I use BIOS from this post? https://www.badcaps.net/forum/showth...ht=lenovo+y500
              Many Thanks
                • 21692
                Many Thanks
                Post your serial number and original bios backup
                • bobok19
                  • Oct 2023
                  • 5
                  • Slovakia
                  SN: YB00345823
                  I really read many guides about ME cleaning and BIOS flashing, but everything fails with using MEAnalyzer. When I want to use it it still ask to install some library for python. Sorry, I am beginner.
                    • 21692
                    SN: YB00345823
                    This thread will help you with MEAnalyzer - https://www.badcaps.net/forum/showth...ght=MEAnalyzer
                    • bobok19
                      • Oct 2023
                      • 5
                      • Slovakia
                      Yes, thanks. I successfully run the MEA yesterday, but I still can´t edit the BIOS and I do not know how to change DMI information (yes, I know it exists guide on this forum, but I think is too complicating for me). Please, can you edit the BIOS for me?
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12281
                        Y500 Laptop (ideapad) - Type 9541
                        • bobok19
                          • Oct 2023
                          • 5
                          • Slovakia
                          Hi, thanks. The BIOS works, but not correctly. I have still problem with power up. Sometimes the laptop boots, sometimes no, especially after shutdown and immediatly turn on.
                          Also when I would like to update BIOS with original utility from Lenovo support - InsydeFlash, the app goes to error - BIOS compare version error. What can I do yet? Can you help me please? Do you have some tips what can be wrong?
                          Thank you
                          • jendkkd jeje
                            Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                            by jendkkd jeje
                            So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                            I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                            10-11-2024, 03:12 PM
                          • joven016
                            Lenovo Ideapad S145 need working bios HELP!!
                            by joven016
                            Problem is blinking power led only
                            i don't know exactly if it's s145-15igm or s145-14igm
                            have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
                            Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
                            Already tested some of posted bios here
                            S145-14igm - success but invalid serial and not booting on OS
                            S145-15igm - success with serial and some other info in bios but still not booting on OS
                            already tried installing new windows but always booting on bios setup
                            windows installer flash drive detected on...
                            08-21-2025, 10:55 PM
                          • AHmad_Salal
                            Need BIOS Dump/ROM for Lenovo Thinkstation p500
                            by AHmad_Salal
                            Hello all,
                            I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                            11-28-2023, 05:28 AM
                          • Ahari
                            by Ahari
                            I...
                            08-13-2025, 06:12 AM
                          • mximiliandz
                            help bios lenovo ideapad s145-14iil type 81w6
                            by mximiliandz
                            Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                            06-20-2025, 06:50 AM
