I need Lenovo IdeaPad Y500 LA-8692P bios dump
  • ibrahim03
    • Oct 2015
    • 142
    • egypt
    main+ec
    thanks advance
  • ibrahim03
    • Oct 2015
    • 142
    • egypt
    Re: I need Lenovo IdeaPad Y500 LA-8692P bios dump
    up up up
    • sopik78
      • Nov 2013
      • 517
      • Czech Republic
      Try this..
      • kapserajug
        • Nov 2017
        • 84698575461
        thank you sir
        visit cialispascherfr24
        • whitevolf
          • Feb 2014
          • 122
          • TÜRKİYE
          thanks
          • spurki
            • Apr 2020
            • 43
            • romania
            not working
            • bobok19
              • Oct 2023
              • 5
              • Slovakia
              Hello, I am new in this branch of BIOS programming. I have problem with BIOS (probably ME region) on Lenovo Y500, type 9541, LA-8692P. After unsuccessfull BIOS flash using InsydeFlash, the laptop wouldn´t turn on, only fan goes, screen was black. I try to flash BIOS using EZP2023+. I used the BIOS from this post - https://www.badcaps.net/forum/showth...ht=lenovo+y500
              After flash, sometimes the laptop turn on and boot Windows, sometimes the fan spins but the screen is black. When I boot Windows, I try to update BIOS with InsydeFlash, but error occurs - BIOS version compare error.
              I think I need clean ME region, but I do not know how. Please, can me help someone?
              Can I use BIOS from this post? https://www.badcaps.net/forum/showth...ht=lenovo+y500
              Many Thanks
                • 20971
                Many Thanks
                Post your serial number and original bios backup
                • bobok19
                  • Oct 2023
                  • 5
                  • Slovakia
                  SN: YB00345823
                  I really read many guides about ME cleaning and BIOS flashing, but everything fails with using MEAnalyzer. When I want to use it it still ask to install some library for python. Sorry, I am beginner.
                    • 20971
                    SN: YB00345823
                    This thread will help you with MEAnalyzer - https://www.badcaps.net/forum/showth...ght=MEAnalyzer
                    • bobok19
                      • Oct 2023
                      • 5
                      • Slovakia
                      Yes, thanks. I successfully run the MEA yesterday, but I still can´t edit the BIOS and I do not know how to change DMI information (yes, I know it exists guide on this forum, but I think is too complicating for me). Please, can you edit the BIOS for me?
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11787
                        Y500 Laptop (ideapad) - Type 9541
                        • bobok19
                          • Oct 2023
                          • 5
                          • Slovakia
                          Hi, thanks. The BIOS works, but not correctly. I have still problem with power up. Sometimes the laptop boots, sometimes no, especially after shutdown and immediatly turn on.
                          Also when I would like to update BIOS with original utility from Lenovo support - InsydeFlash, the app goes to error - BIOS compare version error. What can I do yet? Can you help me please? Do you have some tips what can be wrong?
                          Thank you
                          • mximiliandz
                            help bios lenovo ideapad s145-14iil type 81w6
                            by mximiliandz
                            Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                            06-20-2025, 06:50 AM
                          • jendkkd jeje
                            Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                            by jendkkd jeje
                            So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                            I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                            10-11-2024, 03:12 PM
                          • AHmad_Salal
                            Need BIOS Dump/ROM for Lenovo Thinkstation p500
                            by AHmad_Salal
                            Hello all,
                            I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                            11-28-2023, 05:28 AM
                          • hirens
                            Lenovo ideapad 3 14IGL05 bios dump needed
                            by hirens
                            model: 81wh
                            sn: pf36ta6h
                            board no: nm-c961 gs453/gs553
                            hey guys above is my laptop info
                            it only blinks the power button kindly help me with a working dump
                            old dump attached...
                            07-21-2023, 04:48 AM
                          • lngcs
                            Bios dump need for lenovo ideapad 1 15ALC7
                            by lngcs
                            Hi, could some one please help extract or provide bios dump for Lenovo ideapad1 15alc7, MTM:8244007aau,s/n:pf4k2bzn.thanks...
                            09-24-2024, 11:11 PM
