help 4445s bios
  • aisteru0211
    Banned
    • Jun 2017
    • 18
    • 81166969755
    help 4445s bios
    i need bios for hp 4445s AMD A8 processor or clean this old dump file tnx and advance
  • aisteru0211
    Banned
    • Jun 2017
    • 18
    • 81166969755
    Re: help
    Up pls i need a new one badly needed
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Re: help
      Here, my friend. This is a working dump.
      • aisteru0211
        Banned
        • Jun 2017
        • 18
        • 81166969755
        Re: help
        Tnx bro I try this file then,feedback later
        • SHAIK AFZAL
          • Sep 2020
          • 13
          • India
          Re: help
          bro its 8mb i need 4mb
          thnx
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
          • DynaxSC
            by DynaxSC
            11-17-2023, 10:56 AM
          • grimacelord
            Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
            by grimacelord
            This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
            Motherboard model number: DA0PAMB46A1 REV: A
            Secondary motherboard model number: 0PAB
            SKU: 685K4UA
            Serial number is: 5CD3223BJP
            Recently reflashed this laptop with latest BIOS and once...
            05-07-2024, 08:06 AM
          • DynaxSC
            Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
            by DynaxSC
            I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
            It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
            I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
            11-06-2022, 05:22 PM
          • vinaypundith
            Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
            by vinaypundith
            I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
            So, I'm looking for a BIOS dump for this machine - a 16MB one....
            08-03-2024, 12:32 PM
