Easiest ways to make a dump from BIOS
  • caspian
    • Oct 2015
    • 1589
    • Laptop
    Dear Technicians,
    Most people do not accept removing bios chip to make a bios dump for others.
    It would be great if bios technicians mention some easy steps in this thread for creating a bios dump without removing the chip and without a risky operation on the laptop. In this way, bios dumps will be available for all laptops.
    are there any such steps for various laptop models?
  • guzica
    • Mar 2011
    • 28
    • Serbia
    Re: Easiest ways to make a dump from BIOS
    bios backup toolkit v2.0
    • meritosari
      • Oct 2010
      • 774
      • Indonesia
      What about UEFI bios? Can that the tool handle it?
      IMO:
      Bios backup toolkit only work for OLD mobo. When North and South bridge merge, i think impossible.
      The easiest problems on field of low level chip repair are when you face Shorted on 19V rails and BIOS problems, when you have been lazy to backup from working board, then the question is are them serious doing job repair or not? Except them have capabilities to fix bios or only hope somebody helps, with magic word URGENT, please!.
      The trusted BIOS only from official each vendor, from other dump, you make that be double ID or SN (though it is bios of working). Please think here........I believe that's why on HP laptop DMI need editing to avoid double ID or SN. There is a few things on my head, what happend if someone has success to inject virus on bios UEFI ( I hope not, so scary).
      For fix bios laptop only need read many threads on this forum, the clue of puzzle was here, right on this forum. in example to fix bios of Asus, Mr Ala_borbe already give us a Tutorial for it.
      If you have time do research with one mobo, the key is you have backup (or you can try it with other chip from scrap board or donor). Fill the chip with your works, see what result, if failed just try again, again and again.
      Hint:
      I only work with HxD editor and few tool to extract an encrypted the files from official update. Each brand laptop has different tool to handle it. like Lenovo, HP or DELL. Knowing who is the producer of bios is very important as well. like AMI or insyde.
      Good Luck!
        • 30953
        bios backup toolkit v2.0 just backed up a UEFI bios from a lenovo
          • 30953
          many makers already injected a rootkit into UEFI that downloads spyware files into your windows even if you re-install.
          here it is - i extracted it!!
          it's way beyond "Tinfoil Hats" at this point in time!!!!!
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
          • DynaxSC
            by DynaxSC
            11-17-2023, 10:56 AM
          • grimacelord
            Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
            by grimacelord
            This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
            Motherboard model number: DA0PAMB46A1 REV: A
            Secondary motherboard model number: 0PAB
            SKU: 685K4UA
            Serial number is: 5CD3223BJP
            Recently reflashed this laptop with latest BIOS and once...
            05-07-2024, 08:06 AM
          • DynaxSC
            Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
            by DynaxSC
            I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
            It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
            I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
            11-06-2022, 05:22 PM
          • TacticalFahrrad
            [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
            by TacticalFahrrad
            I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
            BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
            I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
            06-30-2025, 04:09 AM
