hi everyone i need a working bios for this model HPV14AC011TU i have attached the original bios can someone fix this please
hp 14-ac011TU working bios needed
Re: hp 14-ac011TU working bios needed
can you know how to check bios bid?if not search youtube video you will know how to make hp bios.here your bios.Attached FilesComment
thanks friend the problem with this laptop was water damage but i already eliminated the shorted 19v rail and there is a light the prob is turns on 3 seconds and found out there is no 3.3v on pin 8 of the bios but when i pull out the chip and check the pads on pin 8 there is 3.3vComment
i tried replaced the chip and flashed with your bios imanromi but still the same issue turns on seconds off i already slight reflow the cpu but still the same issue there is no 3.3v on pin8 of bios chip but when i pulled out the chip there is 3.3 on the padsComment
motherboard boardcode SKITTL10-6050A2730001-MB-A01 i need working bios for thisLast edited by String2016; 10-09-2017, 06:06 AM.Comment
i already tried flashed the bios above and also change the chip but still the same issue the problem is there is no 3.3v on the bios chip but when i pulled out the chip there is 3.3v on the pads anyone help on this pleaseComment
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM -
Channel: BIOS Requests ONLY!
by techlabHi Guys,
Looking for some help with an HP Elite Dragonfly.
The customer explained it was updating the BIOS, the flashing completed, but afterwards the laptop wouldn’t power back on.- The laptop has no power but does take the correct voltage.
- It shows 5 flashes white/amber, which indicates a BIOS issue.
- I backed up the original BIOS to extract the feature byte etc.
- I then flashed the BIOS with a clean version from HP’s website, but the laptop still gives 5 white/amber flashes.
Just wanted to pick your brains on this — has anyone come across this before or...-
by joven016Problem is blinking power led only
i don't know exactly if it's s145-15igm or s145-14igm
have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
Already tested some of posted bios here
S145-14igm - success but invalid serial and not booting on OS
S145-15igm - success with serial and some other info in bios but still not booting on OS
already tried installing new windows but always booting on bios setup
windows installer flash drive detected on...-
by SparklingxHi,
So i've bough a ch341 programmer, and the chip was CH341B . the test clamp was not working( when connecting bios using test clamp, ch341 device was disconnecting) I tried soldering the bios on the provided board, soldering the bios I could read the chip but could not write or erase. ASprogrammer , neo, ch341a programmer... all programmer software was hanging and device was disconnecting after few second of erase/write operating.
So then I have soldered a capacitor(whatever I had..[10v ~470uf ] ) from VCC to GND on my provided pcb where you solder the bios
now all... - Loading...
