One More Elitebook 2570p Bios Problem
  • maxcombor
    • Sep 2017
    • 7
    • Serbia
    Hello to all this is my first post in this Great Forum .Like all , I have problem with Bios Administrator Password . Please help me .I am read complete Bios with Externall programmer 16Mb.
    Please help me to clean Password, i will like to find solution without loosing Serial ,uuid and all information .If someone need I have Virgin Bios for this motherboard .
    Bios is attached
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: One More Elitebook 2570p Bios Problem
    Here, Check and confirm.
    • maxcombor
      • Sep 2017
      • 7
      • Serbia
      Thanks I will try and confirm.
      • maxcombor
        • Sep 2017
        • 7
        • Serbia
        Thanks mcplslg123, but this is no good solution , same like my other bioses i founded around (diff serial ,etc) and also Virgin one i have (i can change serial in this one ). Problem is all the time on first start "Long Windows Starting Time" Gigabith ethernet and intel managment engine Code 10 ,not start , after restart Intel ME disapear in hardware and Gigabith ethernet lan Working normaly "windows start fast".
        With Original one (with bios password) i do not have this problem . From my point of view also in uefi tool i see different Me and Gbe Region Version Number.
        Please Help me With working Solution because I am desoldered Chip 30 thimes untill now.
        • imranromi
          • Jan 2015
          • 1290
          • Pakistan
          Try this and reply.
          • maxcombor
            • Sep 2017
            • 7
            • Serbia
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Just replace the me region. I hope that will solve the problem of slow start.
              • maxcombor
                • Sep 2017
                • 7
                • Serbia
                Thanks alot imranromi and mcplslg123 , imranromi version works normal (no conflict problems ) only few cosmetic things , How can I change Serial number and product number ??? Any Easy way to unlock MPM or disabling AMT .
                Once Again Thanks,
                thanks,
                thanks,
                thanks to imranromi and mcplslg123
                • kusakhan
                  • May 2018
                  • Pakistan
                  how to use this file .....any method please
                    • 21679
                    Use a bios programmer ,such as TL866, CH341A .
                    • Kamvret
                      • Nov 2019
                      • 6
                      • Indonesia
                      use raspberry pi 2 and SOIC chip clips to flash the bios chip. you dont need to remove your bios chip.
                      • lucaszmn
                        by lucaszmn
                        Problem:
                        Initial Findings:
                        • I concluded that the
                        08-12-2025, 03:01 PM
                      • AquaMan Ua
                        Problem with PANASONIC CF53 laptop after changing BIOS settings
                        by AquaMan Ua
                        Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                        05-17-2025, 09:40 AM
                      • Wutru
                        HP Elitebook 820 G4 BIOS repair assistance required
                        by Wutru
                        Hi guys,
                        If someone would be able to provide some expertise, I'd be very grateful.
                        BIOS Corruption - Cause
                        So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                        After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                        09-06-2025, 10:32 AM
                      • STKR123
                        The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                        by STKR123
                        Greetings badcaps community,
                        I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                        So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                        Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                        I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                        These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                        I learned that desoldering...
                        10-29-2024, 06:03 AM
                      • traxformania
                        TONGFANG "GM7TG7P" Bios Password Problem?
                        by traxformania
                        I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                        But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                        I'm trying to reset my bios without success.
                        I tried :
                        -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                        11-15-2023, 07:32 AM
