Dell mb: La-d051p clear_me
  • lucasa_alvez
    • Jun 2017
    • 13
    • brazil
    DELL MB: LA-D051P CLEAR_ME
    :Rocha::violino:
  • iv4nosky
    • Jun 2013
    • 13
    • Spain
    Re: Dell mb: La-d051p clear_me
    its i7 with discrete gpu? Im looking for that one.
    • keslleyalves
      • Dec 2022
      • Tocantins
      :Rocha::violino:
      tank
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • sahamipoor
        how to Set graphic Discrete mode motherboard(no UMA) Dell XPS L502x - DAGM6CMB8D0
        by sahamipoor
        hello...
        the Dell XPS L502x ( Model P11F ) [ DAGM6CMB8D0 rev.D ..3 of lines output LVDS from PCH has short ohm(0 -70) than LCD displat turn ON but is white !!!
        i decide to change LVDS ports to Lcd from EXT_LCD graphic Studio Discrete to No need it LVDS lines of PCH use...
        according to ُSchematic ,I changed any resistor and... Config_0 and Config_1 EC...but:
        1- EXT_LCD_PWM no voltage to enable pwm
        2-EXT_LVDS_VDDEN no High to Enable LCD_vcc
        and screen is turn off and fan is high Speed!!
        Question:
        I need to Use Discrete graphic nvidia EXT_LCD ports...
        03-12-2024, 02:51 AM
      • Akhlz001
        by Akhlz001
        09-20-2025, 07:15 PM
      • master3112
        by master3112
        07-29-2025, 01:55 PM
        Dell Thunderbolt Firmware
        by SMDFlea
        Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
        Some models have a choice of 2 different firmwares, it depends on the dell SKU.
        The SKU is in brackets (****)
        EDIT: NVM65...
        01-26-2025, 06:22 AM
