DELL E6430s BIOS BIN
  • zenius
    by zenius
    12-08-2024, 06:13 AM
  • capoplays
    Help with BIOS update on Dell G15 5515 after chip replacement
    by capoplays
    Hey everyone,
    I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
    The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
    When I check the BIOS using the F12 menu Flash...
    10-24-2025, 06:53 AM
  • Akhlz001
    by Akhlz001
    09-20-2025, 07:15 PM
  • Sathsul
    Dell Latitude 5431 issues with dumping bios
    by Sathsul
    So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
    The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
    However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
    10-28-2025, 07:49 AM
  • gizaha
    by gizaha
    02-13-2024, 07:18 AM
