HP ProBook 650 G2 6050a2723701-mb-a02
  • saidbe
    • May 2017
    • 42
    • Chilo
    #141
    Re: HP ProBook 650 G2 6050a2723701-mb-a02
    hi,
    i have HP 650 G2 :
    - MB : circus-6050a2723701-mb-a02
    - Chip : 25L12873F
    black screen , fan speed and 3 light of caps after use of RCUnlocker
    I tried some of above bin's but no solution
    No backup , any help?
    • peste
      • Dec 2016
      • 13924
      • ROMANIA
      #142
      Originally posted by saidbe
      hi,
      i have HP 650 G2 :
      - Chip : 25L12873F
      post the original bios of the laptop ... which programmer do you use ??
      • saidbe
        • May 2017
        • 42
        • Chilo
        #143
        i don't make backup, i use Raspberry Pi + clip
        i have same laptop model without bios , i try the bin but without any succes.
          • 22276
          Try these . https://www.badcaps.net/forum/showpo...00&postcount=7 .Without a backup you don`t know which version you had.
          Edit: Where is the bios that you tried with RCUnlocker,wasn`t that your backup ?
          • saidbe
            • May 2017
            • 42
            • Chilo
            #145
            @SMDFlea,
            I tried N76 without any succes but when i reduced the speed to 2000 mhz, i get the screen again.
            Apparently, the speed is crucial.
            Now i get this messages, i search for solutions in other threads.
            But if you have fast solution, is welcome!
            Thank you!
            • hoaca388
              Badcaps
              • Jan 2022
              • 12441
              #146
              @SMDFlea,
              Thank you!
              Try
              • saidbe
                • May 2017
                • 42
                • Chilo
                #147
                @hoaca388,
                It seems not working with this model.
                • kingkong computers
                  • Sep 2018
                  • 214
                  • pakistan
                  #148
                  hello, can someone help me with a repair to a bios dump from a hp probook 650 g2?
                  it powers on and nothing on display, and makes 2 long beels then 2 short ones
                  here is an attachement of the dump. thank you
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12441
                    #149
                    Repaired
                      • Sep 2018
                      • 214
                      • pakistan
                      #150
                      Originally posted by hoaca388
                      Repaired
                      thank you so much its working
                      • florenz
                        • Apr 2018
                        • 50
                        • Cameroon
                        #151
                        Repaired
                        Hello Guys , i have a 650 g2 hp probook with a bios password.
                        Please let someone help me to remove that ...
                        in attach the bios backup
                        thx u so much for your time
                          • 22276
                          Have you tried RCUnlocker or HP Unlocker ? https://www.badcaps.net/forum/showthread.php?t=103570
                          • florenz
                            • Apr 2018
                            • 50
                            • Cameroon
                            #153
                            No ! I was not aware of those methods, sorry...
                            I try to flash another bios of the same PC... I found some on alisaler and so on ... but no result... even to start the PC, was nos possible.
                            Kindly Guide me please
                              • 22276
                              Use the tools mentioned with your original bios backup.
                              If you use a random bios from somewhere else you can have problems.Did you check the alisaler bios BID to make sure it was the right one,was the ME firmware initialised or configured.If you don`t know how to check any of those things don`t go looking for a random bios.
                              • florenz
                                • Apr 2018
                                • 50
                                • Cameroon
                                #155
                                HEY THX u
                                what's the tools use to check BID and ME ? i want to learn more
                                and for the current hp i used hp unlocker like refer me to , it's smoothly thx u , once again and sorry.... i'll read and learn the more
                                • elakhes
                                  • Nov 2015
                                  • 5
                                  • turkish
                                  #156
                                  Hello
                                  i'm having an issue with this laptop when i turn it on i get a black screen and
                                  the fan after a few seconds ramps up until full speed and stays in this state
                                  please help
                                  • Mazorca
                                    • Jan 2017
                                    • 463
                                    Try
                                    • elakhes
                                      • Nov 2015
                                      • 5
                                      • turkish
                                      #158
                                      Originally posted by Mazorca
                                      Try
                                      Thank you very much for my help.
                                      i will try to
                                      • CornholioGSM
                                        • Feb 2014
                                        • 265
                                        • CZECH
                                        #159
                                        hello,
                                        can anyone please check and clean my dump ? ...laptop starts with 3long and 2 short beeps
                                        • hoaca388
                                          Badcaps
                                          • Jan 2022
                                          • 12441
                                          #160
                                          Originally posted by CornholioGSM
                                          hello,
                                          HP ProBook 650 G2 Notebook PC
                                          • studdy05
                                            Bricked HP Probook 450 G7 Bios questions
                                            by studdy05
                                            Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                            Ive got...
                                            07-08-2025, 09:24 PM
                                          • intelg
                                            HP Elitedesk 800 G6 lost BIOS admin password
                                            by intelg
                                            Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
                                            Here is the hardware identification specs:
                                            HP EliteDesk 800 G6 Desktop Mini PC
                                            Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
                                            BIOS ver S21 Ver. 02.05.01 01/05/2021
                                            Born on date: 07/26/2021
                                            SN MXL11841GN
                                            SKU 3X8V9UCHABA
                                            UUID 8116E79EF6FFE94DB0B98A3188270C5C
                                            SYSTEM BOARD ID 8710
                                            SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
                                            11-03-2023, 02:05 AM
                                          • Phad
                                            Seeking help and advice to remove bios admin password – HP ProBook 4520s
                                            by Phad
                                            Dear All,
                                            Hope that this post is at the right place of the forum.
                                            I am seeking help and technical advice to remove bios admin password from HP ProBook 4520s.
                                            The laptop is operating normally and, I am not facing any major issue with it except; the bios admin password that I found about by coincidence only few weeks back.
                                            As the laptop is operating normally, I am reluctant to take it to a workshop to de-solder the bios chip in order to read it by an external programmer, as I am not an expert in doing such a thing.
                                            After...
                                            11-10-2021, 12:05 AM
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • cr4zychriss
                                            by cr4zychriss
                                            • Rebrand: PC Specialist
                                            11-14-2025, 04:04 PM
