HP Probook 450 G2 440 G2 LA-B181P BIOS + 470 G2
  • sellit
    • Jun 2017
    • 104
    • Latvia
    Re: HP Probook 450 G2 440 G2 LA-B181P BIOS
    Hello!
    I have another HP Probook 450 G2 with bricked BIOS, MB model: LA-B181P Rev: 1.0 ZPL40/ZPL50/ZPL70. Can you fix my BIOS dump please?
    Sympoms are: then plug in power it turns on power button led for a moment, then power socket led flashes one time orange and shuts down.
    • alsad
      • Dec 2013
      • 12
      • italia
      Originally posted by SMDFlea
      Try this bios .
      thank fix dmi but problem with ati radeon R5 discrete, these bios for UMA intel
        • 20977
        Your bricked bios has M73 code, i made your new bios from a M73.bin .I just looked at the bios update on HP ,and it has M74 code,thats why the bios didn`t work. I`ll try to make another if i can find a good M74 dump .
          • 20977
          Heres another to try.If you can get it to boot up into windows then update the ME firmware
          https://ftp.hp.com/pub/softpaq/sp660...00/sp66390.exe
            • 20977
            Originally posted by sellit
            Hello!
            Try this one.If you can get it to boot up into windows then update the ME firmware
            • sellit
              • Jun 2017
              • 104
              • Latvia
              #26
              Thanks for help, but no changes, all the same symptoms, thinking maybe not BIOS fault, but something with MB.
                • 20977
                Try this one,if this bios doesn`t work you have other problems.
                • sellit
                  • Jun 2017
                  • 104
                  • Latvia
                  #28
                  All the same, thank you for your help
                  • baby-boy
                    • Jul 2018
                    • deutschland
                    #29
                    Hello
                    I also have a Probook 450 G2, try HP Tools
                    Unfortunately updating the BIOS is not possible.
                    HP Bios Update and Recovery
                    1- Refresh
                    2- Create with USB flash drive for recovery.
                    At the start I press
                    Windows key and B key together
                    Screen stays dark and does not happen.
                    Can someone help me please how I can flash it.
                    • Edu178
                      • Sep 2018
                      • Brasil
                      #30
                      thanks
                      • burak ilgün
                        • Jul 2019
                        • türkiye
                        #31
                        tested working
                        • ruslan657
                          • Mar 2016
                          • 69
                          • Azerbaijan
                          #32
                          thank you working
                          • zmedia
                            • May 2018
                            • 62
                            • Algerie
                            #33
                            Originally posted by peste
                            Hi
                            THANK U BRO
                            • JustX
                              • Feb 2019
                              • 60
                              • iran
                              #34
                              hi, i have a g2 450 laptop i tried all bioses here one of em worked and i got screen, but as soon as i put the parts together and turned on laptop again i have black screen and fan spins at full speed, after that i took all parts apart and i dont have display again till i reprogram the bios. it happens with its own back up bios too, can someone help me with this problem. thanks
                              • zedameo
                                • Jan 2019
                                • 14
                                • algeria
                                #35
                                thank you all for the help
                                • fyaagoub
                                  • Dec 2016
                                  • 269
                                  • maroc
                                  #36
                                  thanks
                                  • rockinho
                                    • Mar 2014
                                    • 13
                                    • Argentina
                                    #37
                                    Originally posted by ruslan657
                                    thank you working
                                    Thanks bro, work very fine on 440/450
                                    • dirigjenti29
                                      • Apr 2018
                                      • 20
                                      • alb
                                      #38
                                      need clear me 470 g2 m73 with graphics
                                      • peste
                                        • Dec 2016
                                        • 12859
                                        • ROMANIA
                                        #39
                                        post the original bios here
                                        • reddevil156
                                          • Aug 2018
                                          • 7
                                          I have a HP probook 470 G2 with a bricked bios. I flashed the bios file from post #1 and the notebook works again.
                                          Now I discovered that the AMD discrete graphics is missing. There should be a AMD R5 255M.
                                          Does someone have a bios dump with amd graphics? I attached my broken dump if it is useful.
                                          • Vesko356
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • Wahaz
                                            by Wahaz
                                            10-30-2023, 08:42 PM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • razor_amd
                                            by razor_amd
                                            12-15-2020, 07:07 PM
                                          • intelg
                                            HP Elitedesk 800 G6 lost BIOS admin password
                                            by intelg
                                            Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
                                            Here is the hardware identification specs:
                                            HP EliteDesk 800 G6 Desktop Mini PC
                                            Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
                                            BIOS ver S21 Ver. 02.05.01 01/05/2021
                                            Born on date: 07/26/2021
                                            SN MXL11841GN
                                            SKU 3X8V9UCHABA
                                            UUID 8116E79EF6FFE94DB0B98A3188270C5C
                                            SYSTEM BOARD ID 8710
                                            SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
                                            11-03-2023, 02:05 AM
