I need bios dump for Microsoft Surface 4
  • DogMaster666
    • Nov 2020
    • 7
    Re: I need bios dump for Microsoft Surface 4
    Originally posted by peste
    try..
    Hi, i found the problem and Solution.
    I read my BIOS with ch341a v 1.18 and get it Verified.
    But while reading and verifieng process it get same erorr message and this message is now stored in the BIOS dump.
    In the latest file what you send me (11.6.25.1229_outimage) check it from
    FFDD50 to the end. So BIOS Region is Bad. (In another bios dumps are offsets differt... i have to check whole BIOS Region)
    I downloaded any Dump for Surface Pro 4 what i can found in web.
    Than i found BIOS what look identical to my original and Replaced it whit FIT.
    The BIOS was from a diferent board (x911788-008 i5 4GB 128GB) my (x911788-009 i5 8GB 256GB).
    But it Works.
    At First Start i got yollow stripe over surface logo. But it boot whitout problems to Windows. After firmware update the stripe is gone.
    After this i run FPTW -greset --> that kills Windows (Bootloop).
    Recovery mode helps! So windows running again.
    Now ME Firmware Works... (V 11.8.70.3626)
    But Touch Firmware is Bad... (V 1.51.250.106.104.239)
    So i have to flash it again.
    Many of BIOS Dumps for SP4 which i downloaded from hire and web have the same Problem like my.
    Only AS Programmer 1.40 get in my case correct dump. (W25Q128FVPQ)
    I will get feedback this weekend after flashing touch firmware.
    Sorry again for my English
    • marcogtt
      • Jan 2021
      • italy
      #42
      hello all, i have a sp4 256gb 8gb.
      It has uefi locked, and battery saving mode is activated to 50%.
      I have downloaded the bios, but when i run ME analyzed i get many errors like this one
      Error: MFS Data Page 1103 > Chunk 3059 CRC-16 0x0000 is INVALID, expected 0x224F!
      this error is popping out on different Pages and many chunk per different pages.
      may this be due to the fact the bios is locked?
      Here attached you'll find the dump .
      could you help me out?
      thank you
      • peste
        • Dec 2016
        • 12521
        • ROMANIA
        #43
        thank you
        try..
        • jjaarah
          • Dec 2020
          • Saudi Arabia
          #44
          Hi Everybody
          I have a surface pro 4 - UEFI password not available - system can't boot up from USB
          what will be my option to overpass the UEFI
          • dahnking
            • Apr 2018
            • 257
            • kenya
            #45
            Originally posted by yhomer
            Thanks friend your file if it works the password is removed.
            perfectly working
            Thank you
            • clrscr
              • Dec 2020
              • 184
              • sing
              #46
              this is my backup. Has a uefi bios password, i Need it removed
              please help me
              thanks!
              all donations are welcome,
              >>>>> click on this link to donate via PayPal. <<<<<
              • onizzbox
                Banned
                • Nov 2018
                • 604
                • Brazil
                #47
                please help me
                thanks!
                @clrscr
                Try!
                • clrscr
                  • Dec 2020
                  • 184
                  • sing
                  #48
                  Originally posted by onizzbox
                  @clrscr
                  Try!
                  it working
                  thanks!
                  • onizzbox
                    Banned
                    • Nov 2018
                    • 604
                    • Brazil
                    #49
                    it working
                    thanks!
                    @clrscr
                    Great! Enjoy your laptop
                    • MAZMAZ22
                      • Jul 2016
                      • 68
                      • ALGERIE
                      #50
                      surface pro 4 no display
                      repair it plz
                      • johnzelix
                        • Sep 2022
                        • 3
                        • Philippines
                        #51
                        Good day everyone. Please help me with my SP4 i5 8GB 256GB. It is stuck on the surface screen with a padlock showing on the top. It is unable to load the OS, enter UEFI settings,and boot from USB. Sorry for my bad english. TIA.
                        • johnzelix
                          • Sep 2022
                          • 3
                          • Philippines
                          #52
                          Sorry, my initial post failed to attach the bios dump. Please help.
                          • peste
                            • Dec 2016
                            • 12521
                            • ROMANIA
                            #53
                            the posted bios are identical... try this..
                            • johnzelix
                              • Sep 2022
                              • 3
                              • Philippines
                              #54
                              Hello, thank you for the quick response. I forgot to mention that I dumped my bios twice just to be sure that I get at least one good dump. I tried the bios and it now boots to OS and touch is working but wifi is not. The system info on the UEFI is not showing my device model, system UUID and serial number, could that be what is causing the wifi issue? I tried to install the SP4 drivers I got from Microsoft but it is not installing with an error saying that my device is not a SP4. BTW my motherboard is X911788-009. Appreciate the help.
                              • Fabregasronaldsr
                                • Jan 2015
                                • 15
                                • Philippines
                                #55
                                Please Help repair my Bios for Microsoft Surface 4
                                Please Help repair my Bios for Microsoft Surface 4 - No Display
                                • Pedross
                                  • Jul 2023
                                  • Portugal
                                  #56
                                  Hello, i have the same problem, BIOS with password local.
                                  Can i connect to the BIOS with a Arduino? Tanks
                                  • peste
                                    • Dec 2016
                                    • 12521
                                    • ROMANIA
                                    #57
                                    for the password you have to post the bios here.. you need a SPI programmer.. watch a video for an example..
                                    https://www.youtube.com/watch?v=DWWigscuQDY
                                    • 08caine15
                                      • Aug 2020
                                      • 18
                                      • Philippines
                                      #58
                                      I can't upload the file..
                                      • volinakis
                                        • Jan 2021
                                        • 2687
                                        • N/A
                                        #59
                                        use winzip or winrar to compress file ...
                                        • hoaca388
                                          Badcaps
                                          • Jan 2022
                                          • 11526
                                          • Viet Nam
                                          #60
                                          CCCCC
