need bios asus K53Sd .motherboard:K53sd rev: 4.2
  • boyebaran
    • Sep 2015
    • 249
    • iran
    hi to all
    need bios asus K53Sd -motherboard part number :K53sd rev: 4.2
    tnx
  • cacla
    • Apr 2015
    • 444
    Re: need bios asus K53Sd .motherboard:K53sd rev: 4.2
    try this one
    • boyebaran
      • Sep 2015
      • 249
      • iran
      tnx cacla
      after programming, main 3.3 &5 v switch to high and zero .blinking power led .no power
      with another bios just have main 3.3 and 5 volt is down.
      • cacla
        • Apr 2015
        • 444
        now is ok?
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Try
          • boyebaran
            • Sep 2015
            • 249
            • iran
            sorry about my mistake
            model is k43sd and motherboard number is K43sd rev:4.2
            • cacla
              • Apr 2015
              • 444
              try this one
              • boyebaran
                • Sep 2015
                • 249
                • iran
                hi
                after programing with (K43SDF1206) now 3.3 is present and 5 volt is about 0.9 volt.
                rt8206 replaced and no change.
                please help.
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Lift the 5v coil and see which side is shorted and trace further. You must have some short in 5v line
                  • boyebaran
                    • Sep 2015
                    • 249
                    • iran
                    Originally posted by cacla
                    try this one
                    is the file trusted?
                    i am not sure for trusted bios.it is my first problem.
                    with some file 3.3 is fix and 5 volt is down.with another file both is zero and with another one ,blinking led power .
                    • mukasyah
                      • Dec 2017
                      • malaysia
                      Try
                      recomend, workin
                      • razor_amd
                        by razor_amd
                        12-15-2020, 07:07 PM
                      • pirati
                        by pirati
                        10-27-2025, 04:20 PM
                      • jbonavita
                        by jbonavita
                        Some issues
                        Things I tried
                        04-29-2025, 09:38 PM
                      • throwaway327
                        by throwaway327
                        Model No: RC72LA
                        Serial No: SBNVKD001014459
                        06-18-2025, 05:52 PM
                      • lrouw84
                        by lrouw84
                        Hi there,
                        01-28-2023, 01:31 PM
