asus k42ja rev:2.0 fan 100% working.Need bios
  • s.m.hosein
    • Jun 2015
    • 23
    • esf
    asus k42ja rev:2.0 when i power up the board few seconds later the fan start insanely working .... first the heatpipe was very hot so i porgrammed the bios now the pipes are cooler but still fan working
    its seem the problem is with me region bios so anyone have a fixed and good dump for me?
    thanks !
  • s.m.hosein
    • Jun 2015
    • 23
    • esf
    Re: asus k42ja rev:2.0 fan 100% working
    any idea?
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Upload your dump so that others can fix the me region if you cant fix it on your own.
      • cacla
        • Apr 2015
        • 444
        Try this dump
        • darkrose23
          • Oct 2012
          • IRAN
          Re: asus k42ja rev:2.0 fan 100% working.Need bios
          thank you work foe me
          k42ja_mb rev:2.0
          • jbonavita
            by jbonavita
            Some issues
            Things I tried
            04-29-2025, 09:38 PM
          • throwaway327
            by throwaway327
            Model No: RC72LA
            Serial No: SBNVKD001014459
            06-18-2025, 05:52 PM
          • lrouw84
            Asus vivobook s510ua bios changed to x510un
            by lrouw84
            Hi there,
            I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
            I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
            01-28-2023, 01:31 PM
          • DynaxSC
            by DynaxSC
            06-14-2024, 03:49 PM
          • oragano
            ASUS ex-b250-V7 motherboard bios corrupted - by me
            by oragano
            hey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
            So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
            i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...
            10-17-2024, 02:53 AM
