bios yoga2 11 nm-a201
  • alirafee
    • Jun 2015
    • 91
    • iran
    hi
    i need bios lenovo yoga 2 11
    nm-a201
  • andrew25
    • Feb 2016
    • 223
    • Malawi
    Re: bios yoga2 11 nm-a201
    i need too... did you find it
    • mrodriguezjurado
      • Jan 2014
      • 4
      • Argentina
      testeada ok
      • fharlock999
        • Nov 2017
        • 62
        • Chile
        thanks!
        • gerardo
          Engineer
          • Feb 2016
          • 59
          • Argentina
          Originally posted by mrodriguezjurado
          testeada ok
          Thanks you!
          • Blackam8899
            • Sep 2020
            • 45
            • Rosario
            testeada ok
            OK
            • Blackam8899
              • Sep 2020
              • 45
              • Rosario
              Does anyone have the ec for this equipment?
              • lucaszmn
                by lucaszmn
                Problem:
                Initial Findings:
                • I concluded that the
                08-12-2025, 03:01 PM
              • AYsys
                Lenovo Yoga X1 Gen4 - Faulty Bios or what is going on?
                by AYsys
                Hello dear forum members,
                I own two Lenovo Yoga X1 Gen 4 laptops. One of them had a touchscreen problem, and I tried to fix it by externally flashing the BIOS. Unfortunately, I didn’t save the original BIOS and accidentally flashed it with a faulty one. After that, the device stopped working completely.
                I then had the idea to make a BIOS backup from the other Yoga X1 Gen 4 (same hardware) and flash it onto the non-working device.
                Nothing was flashed here — the BIOS was only backed up.
                I created the backup using a CH341A Black programmer and NeoProgrammer....
                09-13-2025, 11:05 AM
              • Wahaz
                by Wahaz
                10-30-2023, 08:42 PM
              • HotSaladMan
                Lenovo ThinkBook 14S Yoga ITL Bad Flash + Need Bios
                by HotSaladMan
                *##*#*#*#*#*#Cringe Warning Used Clips for Tl866ii Plus Backups#*#*#*#*#*#
                Model : Lenovo ThinkBook 14S Yoga ITL
                S/N : MP28JT19
                MFG Date : 2022/02/09
                Factory ID PRC4
                MO : MPNXB26080FX
                MTM : 20WE001US
                MODULE FCC ID : PD9AX201NG
                IC : 1000M-AX201NG
                BOARD INFO
                FLV34 LA-KO51P
                REV : 1B 2020-08-24
                Bit of Info
                Using Tl866ii Plus, it would scan the chip but wouldn't not detect the
                chip id, so i would always uncheck the id check, so it would bypass the error
                i did in fact make...
                11-07-2024, 07:46 AM
              • beogeek
                Lenovo Yoga Slim 7 14APU8 Bios Request
                by beogeek
                I've currently got a Lenovo Yoga Slim 7 14APU8 that is not posting. Its fan spins, the keyboard lights up, and the caps lock doesn't work. It was taken to some shop for cleaning, and then they updated or tried to update the bios. After that, there was no display and no post. I've removed the bios ic from the board and made a bios dump. I need some assistance going forward, as I suspect this is probably just a bad bios issue. I've tried searching for a dump, but no luck; if anyone can throw me a bone, it would be much appreciated!
                Attached is the bios dump in the state I received it...
                10-24-2024, 12:54 PM
