Acer One 14 Z1401-C9JN bios
  • lorins_core
    BlackSmith
    • Dec 2012
    • 552
    • Philippines
    Acer One 14
    Model Name: Z1401-C9JN
    Need Bios File... Thanks
  • meritosari
    • Oct 2010
    • 774
    • Indonesia
    Re: Acer One 14
    Try this
    • jasfell
      • Nov 2016
      • 11
      • philippines
      Re: Acer One 14
      hello sir meritosari. i downloaded the bios you have uploaded and its working. one problem is the usb cannot detect...all of the three usb. i have tried other bios too and it has the same problem. my question is. what is the other ic usb controller or any ic that is responsible of controlling the usb ports? please giv me a solution.thank you.
      • fddizon
        • Sep 2011
        • 555
        • Philippines
        Re: Acer One 14
        Check USB port 5 volts if present
        • Andyservo
          • Jun 2013
          • 152
          • Indonesia
          Re: Acer One 14 Z1401-C9JN bios
          big thanks...
          • techspecs
            • Nov 2015
            • pilipphines
            hi sir can i flash this one in board id ncbt411 mb ver 2.0 same model acer one14 z1401
            • peste
              • 13865
              • ROMANIA
              better post the original bios here ..
              • clmorre
                • Aug 2020
                • 8
                • Philippines
                Re: Acer One 14
                Originally posted by meritosari
                Try this
                Will the bios work for z1401-C7J6?
                board code is ncbt411 ver 2.0
                • markGomez
                  • Jan 2021
                  • Philippines
                  Re: Acer One 14
                  Try this
                  hello how can i solve "FILE LENGTH" issue in bios flashing?? thanks
                  • peste
                    • 13865
                    • ROMANIA
                    Re: Acer One 14
                    What problem do you have? give you more details ..
                    • charls2021
                      • Oct 2021
                      • philippines
                      its working thanks
                      • to5it0
                        by to5it0
                        10-24-2025, 01:35 AM
                      • Citymin
                        by Citymin
                        S/N : 5RNK9FFT70...
                        08-05-2025, 05:12 AM
                      • maanee11
                        Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
                        by maanee11
                        Hello Everyone,
                        I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
                        It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
                        In the website, you can only see specs etc.
                        I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
                        11-08-2025, 04:08 AM
                      • Danfay
                        Acer Aspire 3 A317-51G Request Bios in .bin file
                        by Danfay
                        Hello, I have an Acer Aspire 3 A317-51G, with a QH128AHIG XMC chip.
                        Due to a problem when I turn off the computer, I tried to upgrade the bios through Windows (10), this is the only possibility to update in Acer. Unfortunately, something went wrong . The laptop starts but I can't even access the Bios. I searched for a long time, without success, for the Bios version in .bin file .
                        The last functional Bios version was: InsydeH20, Rev. 5.0, Version 1.09 .
                        So I updated to version 1.11, which apparently either went wrong or is not functional.
                        Does anyone...
                        09-25-2023, 02:57 AM
                      • m1ch43lzm
                        by m1ch43lzm
                        Hi everyone
                        09-06-2025, 05:47 PM
