Acer One 14 Z1401-C9JN bios
  • lorins_core
    BlackSmith
    • Dec 2012
    • 552
    • Philippines
    Acer One 14
    Model Name: Z1401-C9JN
    Need Bios File... Thanks
  • meritosari
    • Oct 2010
    • 774
    • Indonesia
    Re: Acer One 14
    Try this
    • jasfell
      • Nov 2016
      • 11
      • philippines
      Re: Acer One 14
      hello sir meritosari. i downloaded the bios you have uploaded and its working. one problem is the usb cannot detect...all of the three usb. i have tried other bios too and it has the same problem. my question is. what is the other ic usb controller or any ic that is responsible of controlling the usb ports? please giv me a solution.thank you.
      • fddizon
        • Sep 2011
        • 555
        • Philippines
        Re: Acer One 14
        Check USB port 5 volts if present
        • Andyservo
          • Jun 2013
          • 152
          • Indonesia
          Re: Acer One 14 Z1401-C9JN bios
          big thanks...
          • techspecs
            • Nov 2015
            • 3
            • pilipphines
            hi sir can i flash this one in board id ncbt411 mb ver 2.0 same model acer one14 z1401
            • peste
              • Dec 2016
              • 13679
              • ROMANIA
              better post the original bios here ..
              • clmorre
                • Aug 2020
                • 8
                • Philippines
                Re: Acer One 14
                Originally posted by meritosari
                Try this
                Will the bios work for z1401-C7J6?
                board code is ncbt411 ver 2.0
                • markGomez
                  • Jan 2021
                  • Philippines
                  Re: Acer One 14
                  Try this
                  hello how can i solve "FILE LENGTH" issue in bios flashing?? thanks
                  • peste
                    • Dec 2016
                    • 13679
                    • ROMANIA
                    Re: Acer One 14
                    What problem do you have? give you more details ..
                    • charls2021
                      • Oct 2021
                      • philippines
                      its working thanks
                      • to5it0
                        Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                        by to5it0
                        Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                        I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                        This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                        I have opened the laptop and identified the main BIOS chip...
                        10-24-2025, 01:35 AM
                      • Citymin
                        by Citymin
                        S/N : 5RNK9FFT70...
                        08-05-2025, 05:12 AM
                      • Danfay
                        Acer Aspire 3 A317-51G Request Bios in .bin file
                        by Danfay
                        Hello, I have an Acer Aspire 3 A317-51G, with a QH128AHIG XMC chip.
                        Due to a problem when I turn off the computer, I tried to upgrade the bios through Windows (10), this is the only possibility to update in Acer. Unfortunately, something went wrong . The laptop starts but I can't even access the Bios. I searched for a long time, without success, for the Bios version in .bin file .
                        The last functional Bios version was: InsydeH20, Rev. 5.0, Version 1.09 .
                        So I updated to version 1.11, which apparently either went wrong or is not functional.
                        Does anyone...
                        09-25-2023, 02:57 AM
                      • m1ch43lzm
                        Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                        by m1ch43lzm
                        Hi everyone
                        I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                        Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                        Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                        There's also an extra OTP Secu.R...
                        09-06-2025, 05:47 PM
                      • Forest79
                        by Forest79
                        However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                        07-23-2023, 07:39 AM
