Macbook pro a1502 Password
  • sassan
    • Apr 2014
    • 74
    • France
    i have a macbook pro A1502 whenever it boots it says "your computer is disabled.try again in 60 minutes"
    and when i try to boot it in recovery using command+R it request a password.
    the motherboard number is 820-3476-A ,it has 25Q064A CHIP.
    can i read this chip using the minipro and remove the password.
    Thank you.
  • kesmeseker
    • Jan 2015
    • 121
    • turkey
    Re: Macbook pro a1502 Password
    Use backup first. 2 bios working. 2. bios turkish.
    http://dosya.co/p89b7t5bvw0x/820-3476-a.7z.html
    • sassan
      • Apr 2014
      • 74
      • France
      Thank you,but how can i read the chip 25Q064A using minipro.is there a special adapter for it?
      • Pascal Komlassan
        • Jan 2017
        • 809
        • TOGO
        Thank you bro.very good
        • ibrahim11
          Banned
          • May 2018
          • 6
          • japony
          Hello
          How can i read bios chip for apple A1466,A1502 etc using minipro tl866, rt809f, svod,.is there a special adapter for it?
          • ibrahim11
            Banned
            • May 2018
            • 6
            • japony
            Originally posted by ibrahim11
            Hello
            please help me
            • RAR1991
              • Apr 2017
              • 25
              • Algérie
              of curse the MiniPro is capable to read the 25Q064A but you have to use a DIP8 adapter to solder the chip on it.
              • ibrahim11
                Banned
                • May 2018
                • 6
                • japony
                i know this and i have it
                but i want to read it without chip desolder form motherboard
                • ictc
                  • May 2015
                  • 46
                  • Italy
                  You should buy an adapter that fits the connector on the motherboard. There is a company on internet that sells that part and also a variant of the same system that contains also the password clean bios. That cost a lot and I consider it a must if you do many of this repairs otherwise I suggest to desolder the chip and connect wires to it and connect those to the mini pro.
                  • ibrahim11
                    Banned
                    • May 2018
                    • 6
                    • japony
                    can you tell me this company to buy the adapter
                    • mferna14
                      Password removal on MacBook Pro A2159
                      by mferna14
                      Hi friends., I am working on MacBook Pro A2159 touchbar 2019. The old logic board was liquid spilled so I ordered another logic board from AE. Received it & all worked fine till I got to the Chinese login screen where the login screen password tobe entered. I tried to reset the password but it again gave me options which I do not know about the Apple ID. I formatted the onboard SSD. & wanted to change the startup boot sequence but in order to change it, again the password is needed for that too. Is there a way to get rid of this password?? The seller has not replied back past 2 days, how...
                      05-13-2025, 04:16 PM
                    • ritalo
                      MacBook Air 13 2014 - Remove EFI password
                      by ritalo
                      I have a MacBook Air 13 inches 2014.
                      I have set a EFI password and I can't remember it : now I want to reinstall macOS and I can't because the MacBook is asking for the password.
                      I know how to remove the password with a usb programmer.
                      I plug the usb programmer to the motherboard and to my pc with usb, I read the EFI and I save it to a file.
                      Then I have to find this value in the file : $SVS because it indicate where is the password.
                      But I can't find the value.
                      I have attached the file​
                      Thank...
                      05-14-2024, 12:10 PM
                    • Danielreinaa
                      HELP need password bios Macbook A1706
                      by Danielreinaa
                      Hola chicos, espero estén bien, he estado buscando información para aprender a hacer eliminación de password EFI en macbooks.
                      Actualmente tengo un problema con una macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
                      Si podrian ayudarme les agradeceria mucho o algun link para aprender a hacerlo y no volver a molestarles.
                      gracias de antemano y que tengan una linda tarde, disculpen si estoy rompiendo alguna norma.
                      Hi guys, I hope you are doing well, I have been looking for information to learn how to remove the EFI password on macbooks.
                      09-07-2024, 03:47 PM
                    • gbuniva
                      MacBook A1502 (820-3476-A) Repair case with solution
                      by gbuniva
                      Hi everyone, I want to share my tech experience with a MacBook Pro A1502 late 2013 that won´t turn on.
                      The computer arrived dead, when connected to Magsafe no lights on the connector.
                      Here some Measures at some testpoints on de LB 820-3476-A :
                      PP3V42_G3H 1.7V
                      PPBUS_G3H = 0V
                      PPVBAT_G3H_CHGR_RE = 0V
                      PP3V3_S5 = 0V
                      PP5V_S4 = 0V
                      P5V1_SW = 5.5V
                      PP3V3_S0SW_SSD =0V
                      PP3V3_S0SW_SSD_FET =0V
                      PPDCIN_G3H_INRUSH = 16.10V
                      PPDCIN_G3H_CHGR = 16.10V
                      PP5V_S5 - 0v
                      PP3V3_S5 - 0v
                      PP3V3_SUS - 0V
                      PM_RSMRST_L - 0v...
                      04-09-2025, 07:11 PM
                    • Nopslide
                      by Nopslide
                      04-01-2024, 04:27 PM
