asus x55c (x55vd rev2.1) dump
  • svetec
    • Aug 2015
    • 24
    • Macedonia [FYROM]
    Hi, I flashed bios with the dump x55vd from internet, pc boot, but fan is always on maximum. can some one give me a correct dump or fix this dump.
    Thanks.
  • kiraro
    • Jan 2016
    • 177
    • North NY
    Re: asus x55c (x55vd rev2.1) dump
    see here :
    https://www.badcaps.net/forum/showthread.php?t=47543
    • svetec
      • Aug 2015
      • 24
      • Macedonia [FYROM]
      I try this files, but fan is always on maximum with them.
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        did you save backup of nonworking bios? if yes, post it here
        Im Back... sort of...
        • svetec
          • Aug 2015
          • 24
          • Macedonia [FYROM]
          No I didn`t backup the old bios. I find this bios working nice, fan is normal and everything is ok. thanks for help.
          • yalcinfakir@gmail.com
            • Dec 2017
            • 6
            • TR
            svetec Booss süpper fan normal..Teşekkürler..
            • cihancyber
              • Mar 2017
              • 22
              • tejhi
              thanks
              • Deby
                • Aug 2015
                • 120
                • Serbia
                Bios works. I had the same problem with x55vd. The fan was running at maximum. With X55CF1 Works normally. Thanks!!
                • Philippe_Quercy
                  • Sep 2021
                  • France
                  hello, how do you flash the bios X55CF1.409 ?
                  What soft do you use ?
                  • Comrad_SU
                    • Feb 2014
                    • 31
                    • Ukraine
                    • Electronics
                    Thank You Bro! It's working fine!
                    • ronaldopdias
                      ASUS ROG Strix B660-I Gaming WiFi – BIOS dump vs ASUS CAP size mismatch, need corruption check, please.
                      by ronaldopdias
                      I’m troubleshooting an ASUS ROG Strix B660-I Gaming WiFi motherboard and I’m a bit stuck at the BIOS level. What I’ve tried so far
                      • Attempted to flash the BIOS using the USB BIOS FlashBack (Q-Flash) port with a properly formatted FAT32 USB drive.
                      • BIOS file downloaded directly from the official ASUS support page.
                      • Followed the exact FlashBack procedure (correct port, renamed file, standby power only).
                      Issue:
                      The FlashBack LED does not blink at all — no activity whatsoever. Further investigation
                      Because FlashBack didn’t work, I:
                      • Removed the BIOS SPI IC from
                      02-04-2026, 03:16 AM
                    • DrSAS
                      ASUS UP6502ZA - 16MB SPI dump request - No boot
                      by DrSAS
                      I'm trying to recover a ASUS Zenbook Pro 15 Flip OLED (model UP6502ZA, serial R1N0CV06A262028, motherboard 60NB0W20-MB1030) which stopped booting after a Windows 11 update. The laptop powers on but there's no display and no POST.
                      I have a CH341A v1.612 programmer with a WSON 6x5mm pogo adapter. I managed to get two identical consecutive reads, so I believe my corrupted dump is "reliable".
                      I've spent the last few days trying to prepare a flashable image from the official ASUS bios file (UP6502ZAAS.312, 19MB) downloaded from their...
                      12-24-2025, 04:23 PM
                    • Jokker_77
                      ASUS X1500EA-BR3993W BIOS corrupted - need help repairing dump
                      by Jokker_77
                      Hello everyone, I need help repairing the BIOS of my ASUS X1500EA-BR3993W laptop.
                      Symptoms:
                      LED flashes for ~30 seconds then battery LED turns solid red
                      Fan spins briefly then stops
                      No POST, no display output
                      Ctrl+Home recovery does not work
                      Hardware info:
                      Model: ASUS X1500EA-BR3993W
                      BIOS chip: GigaDevice GD25B128ES1G (16MB SPI Flash)
                      Platform: Intel Tiger Lake (11th Gen)
                      What I've tried:
                      CH341A programmer with SOIC8 clip
                      Flashed X515EA R6.0 dump → gives 2 long LED blinks (RAM error)
                      Original ASUS X515EAAS.316 (19MB...
                      05-29-2026, 09:10 PM
                    • kinojk2
                      ASUS Prime Z790-P (NON-WIFI) Bios dump and questions
                      by kinojk2
                      Hi, Thanks for all you do here.
                      I have attached my 16MB dump.
                      EDIT2: All hardware working fine, I think I just need to update my linux booatloader and all gucci
                      EDIT:
                      I can get into bios now! I reflashed as instructed elsewhere. With a minimal POST (just 1 stick of ram , GPU, CPU, no drives) I have loaded into BIOS. I am about to reinstall my other hardware components now.
                      The clips are such a pain to use, soldering would be a great skill to have.
                      Thanks for the advice in other threads!
                      To answer my own question, I didn't...
                      03-24-2026, 05:55 AM
                    • mits43
                      Asus Prime X570 Pro Bios Dump
                      by mits43
                      For whoever may need it....
                      05-24-2026, 03:11 AM
