i need BIOS file for hp probook 455 G3
  • salmanzeiad
    • May 2016
    • 68
    • world
    i need BIOS file for hp probook 455 G3...
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: i need BIOS file for hp probook 455 G3
    post your backup
    Im Back... sort of...
    • salmanzeiad
      • May 2016
      • 68
      • world
      Originally posted by ala_borbe
      post your backup
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        read your non working bios and post here
        • salmanzeiad
          • May 2016
          • 68
          • world
          ok>>>i will do
          • salmanzeiad
            • May 2016
            • 68
            • world
            ok >>>take it
            • salmanzeiad
              • May 2016
              • 68
              • world
              https://drive.google.com/open?id=0B-...S10OXFEblJCVE0
              • ala_borbe
                aka Donald
                • 1625
                • Malta
                download from hp site
                http://ftp.hp.com/pub/softpaq/sp78001-78500/sp78262.exe
                extract with winrra or 7zip
                there will be 2x8mb files
                N79_0114.bin
                N80_0114.bin
                one is your bios
                • salmanzeiad
                  • May 2016
                  • 68
                  • world
                  N79_0114.bin
                  N80_0114.bin
                  one is your bios
                  thanks>>>i`ll try..
                  • salmanzeiad
                    • May 2016
                    • 68
                    • world
                    Originally posted by salmanzeiad
                    thanks>>>i`ll try..
                    you sure..?!
                    not work
                    • salmanzeiad
                      • May 2016
                      • 68
                      • world
                      N79_0114.bin
                      N80_0114.bin
                      one is your bios
                      not work
                      • ala_borbe
                        aka Donald
                        • 1625
                        • Malta
                        then it is not bios problem
                        • andrew25
                          • Feb 2016
                          • 223
                          • Malawi
                          HP Probook 455 G3
                          here is a working dump for HP probook 455 G3
                          dax73amb6f0 rev:f (X73A)
                          AMD... N79
                          • AHED
                            • Aug 2020
                            • 6
                            • maroc
                            Re: HP Probook 455 G3
                            Thanks bro
                            • armands0212@gmail.com
                              • Oct 2021
                              • 28
                              • Latvia
                              HP Probook 455 G3 Bios bin DAX73AMB6F0 REV F
                              Hi all.i have problem with this bios.original had password so i flashed it with ch341A tool with bios from hp website and now it shows this warning everytime i boot it up- System is booting in manufacturing program mode;32
                              Can someone post good bios bin file or maybe adjust mine?
                              P.s i already tried to disable banufacture mode on bcu tool but no luck
                                • 21692
                                Re: HP Probook 455 G3 Bios bin DAX73AMB6F0 REV F
                                Serial number ?
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12281
                                  You must reset DMI for it.
                                    • 21692
                                    "System is booting in manufacturing program mode;32"
                                    The number decrements by 1 each reboot, it will lock itself when it reaches 0 .
                                      • Oct 2021
                                      • 28
                                      • Latvia
                                      How to do that?thanks
                                        • Oct 2021
                                        • 28
                                        • Latvia
                                        so when it will reach 0 it will go to normal boot mode?thanks
                                        • m1ch43lzm
                                          Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                                          by m1ch43lzm
                                          Hi everyone
                                          I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                                          Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                                          Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                                          There's also an extra OTP Secu.R...
                                          09-06-2025, 05:47 PM
                                        • studdy05
                                          Bricked HP Probook 450 G7 Bios questions
                                          by studdy05
                                          Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                          Ive got...
                                          07-08-2025, 09:24 PM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • Forest79
                                          by Forest79
                                          However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                          07-23-2023, 07:39 AM
                                        • black0hackers
                                          Need backup bios file X1 carbon Gen 10 nm-d961 rev 2.0
                                          by black0hackers
                                          my bios ic is die. so i want backup file to make bios
                                          some one have can give me. thank you all
                                          jyg70/jx4c0
                                          03-23-2023, 03:34 AM
