Toshiba C50 Dual Bios programming
  • lagouzas
    Nemesis3
    • Oct 2013
    • 28
    • Greece
    Hello guys, I am relatively new to bios programming, but I try to get deeper, I hope you could help me. I have a piece of art 500$ programmer that I do my job most of the times, right now I am stuck in a laptop with dual bios chip I guess. Model is Toshiba Satellite C50-A-19T, it has 2 bios chips, 25Q16BVSIG and 25Q32BVSIG. I have downloaded the latest insyde bios from Toshiba site in .fd format, renamed the .fd file to .bin file, and reprogrammed succesfully the 25Q16BVSIG chip. The laptop had some common bios failure function with blank screen and some leds, but now it turns on by itself on ac adapter insertion blinking all the leds. Any help would be helpful, I ve never occupied with a laptop with dual bios chips.
    Seing is Believing
  • naeemshahzad
    • Jan 2015
    • 129
    • uae
    Re: Toshiba C50 Dual Bios programming
    motherboard number should write maybe i have
    • rioreno
      • Feb 2009
      • 540
      • Indonesia
      you cannot only write that .fd file from toshiba direct to that chip, you must split that fd file first...
      post your .fd file that you get from toshiba, i will split for you,
      and more better if you post your old backup bios (4mb and 2mb) too.
      • techman1025
        • Jun 2014
        • 497
        Here are the file"s you need all new updates even ME REgion. You will find the 4MB file and the 2MB file just make sure you load the correct firmware in each chip. So you know the next time always original file is needed so when asking for a bios file always upload original this is how you know where to cut out the correct size file's out of the update...I could do it without original because i'm doing this so long.
        enjoy
        Techman1025
        • lagouzas
          Nemesis3
          • Oct 2013
          • 28
          • Greece
          You guys are awesome! Very quick responses... thank you very much... I hope I haven't damaged the laptop so far with my experiments..
          Seing is Believing
          • lagouzas
            Nemesis3
            • Oct 2013
            • 28
            • Greece
            The laptop is up and functional, special thanks to techman1025, but all these seem really weird to me. Could anyone explain to me how should I see the original separated bios files, to send them to you? Should I export them from each original bios chip? I haven't found any functions of exporting data files from bios chips in my programmer's GUI application.
            Seing is Believing
            • techman1025
              • Jun 2014
              • 497
              Hi
              All you need to do is pull the chip read it and back it up save it as original file model name and upload it.
              Techman1025
              • UGUR CELΔ°K
                • Jun 2017
                • turkiye
                Hi .. Bemim computer Toshiba Satellite L50-A-1D4
                PART NO: PSKK6E-04405WTE
                ANAKART: H000057720 WKD51
                BIOS RIBBONS: 25Q32FVSIQ and 25Q16DVSIQ
                I need to reload bios, but I can not find the main bios software.
                Thanks for your help.
                • techman1025
                  • Jun 2014
                  • 497
                  Here
                  Techman1025
                  • thor33
                    • Sep 2023
                    • 0
                    • EspaΓ±a
                    Hello good afternoon, I have a problem with a Toshiba C50-A-1GU with PART NO. PSCGNE-00F00LCE, with bios chip 25Q16DVSIQ and 25Q32FVSIQ does not start, and desoldering the bios chip I have made backup,then erased the chip and flashed them again without success,I hope you help me and apologize for the google translator,I expect your reply thank you in advance
                    TOSHIBA SATELLITE C50-A-1GU
                    • thor33
                      • Sep 2023
                      • 0
                      • EspaΓ±a
                      Toshiba C50 problem dual bios
                      bump. Any help please
                        • 20682
                        Re: Toshiba C50 problem dual bios
                        Please post the laptop serial number,it should be on the label on the base cover.
                        • thor33
                          • Sep 2023
                          • 0
                          • EspaΓ±a
                          Hello SMDFLEA, I don't know how to publish a post, every time I publish something it is either banned or moved, I had all the data entered and all the information about the computer and the bios files, I don't know how to publish, thank you
                            • 20682
                            You have already posted your request at post #10, the bios and info is there. All you had to do was post the word bump,you did not have to make a new thread.
                            Anyway,the serial number should be on a sticker on the bottom case,we have the short toshiba part number though "PSCGNE" so someone should be able to help .
                            • thor33
                              • Sep 2023
                              • 0
                              • EspaΓ±a
                              Thank you for your help and patience, I hope someone can help me
                                by SMDFlea
                                Bad...
                                09-02-2021, 04:40 PM
                              • Vesko356
                                by Vesko356
                                08-11-2023, 03:27 AM
                              • jbonavita
                                by jbonavita
                                Some issues
                                Things I tried
                                04-29-2025, 09:38 PM
                              • zenius
                                by zenius
                                12-08-2024, 06:13 AM
                              • Wahaz
                                by Wahaz
                                10-30-2023, 08:42 PM
