Hello guys, I am relatively new to bios programming, but I try to get deeper, I hope you could help me. I have a piece of art 500$ programmer that I do my job most of the times, right now I am stuck in a laptop with dual bios chip I guess. Model is Toshiba Satellite C50-A-19T, it has 2 bios chips, 25Q16BVSIG and 25Q32BVSIG. I have downloaded the latest insyde bios from Toshiba site in .fd format, renamed the .fd file to .bin file, and reprogrammed succesfully the 25Q16BVSIG chip. The laptop had some common bios failure function with blank screen and some leds, but now it turns on by itself on ac adapter insertion blinking all the leds. Any help would be helpful, I ve never occupied with a laptop with dual bios chips.
Toshiba C50 Dual Bios programming
Re: Toshiba C50 Dual Bios programming
you cannot only write that .fd file from toshiba direct to that chip, you must split that fd file first...Hello guys, I am relatively new to bios programming, but I try to get deeper, I hope you could help me. I have a piece of art 500$ programmer that I do my job most of the times, right now I am stuck in a laptop with dual bios chip I guess. Model is Toshiba Satellite C50-A-19T, it has 2 bios chips, 25Q16BVSIG and 25Q32BVSIG. I have downloaded the latest insyde bios from Toshiba site in .fd format, renamed the .fd file to .bin file, and reprogrammed succesfully the 25Q16BVSIG chip. The laptop had some common bios failure function with blank screen and some leds, but now it turns on by itself on ac adapter insertion blinking all the leds. Any help would be helpful, I ve never occupied with a laptop with dual bios chips.
post your .fd file that you get from toshiba, i will split for you,
and more better if you post your old backup bios (4mb and 2mb) too.Comment
Here are the file"s you need all new updates even ME REgion. You will find the 4MB file and the 2MB file just make sure you load the correct firmware in each chip. So you know the next time always original file is needed so when asking for a bios file always upload original this is how you know where to cut out the correct size file's out of the update...I could do it without original because i'm doing this so long.
enjoy
Techman1025Attached Filesif you find these attachements useful please consider making a small donation to the site
The laptop is up and functional, special thanks to techman1025, but all these seem really weird to me. Could anyone explain to me how should I see the original separated bios files, to send them to you? Should I export them from each original bios chip? I haven't found any functions of exporting data files from bios chips in my programmer's GUI application.Seing is Believing
Hi
All you need to do is pull the chip read it and back it up save it as original file model name and upload it.
Techman1025Comment
Hi .. Bemim computer Toshiba Satellite L50-A-1D4
PART NO: PSKK6E-04405WTE
ANAKART: H000057720 WKD51
BIOS RIBBONS: 25Q32FVSIQ and 25Q16DVSIQ
I need to reload bios, but I can not find the main bios software.
Thanks for your help.Comment
Here
Hello good afternoon, I have a problem with a Toshiba C50-A-1GU with PART NO. PSCGNE-00F00LCE, with bios chip 25Q16DVSIQ and 25Q32FVSIQ does not start, and desoldering the bios chip I have made backup,then erased the chip and flashed them again without success,I hope you help me and apologize for the google translator,I expect your reply thank you in advance
TOSHIBA SATELLITE C50-A-1GU
.Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: Toshiba C50 problem dual bios
Please post the laptop serial number,it should be on the label on the base cover.
.Comment
Hello SMDFLEA, I don't know how to publish a post, every time I publish something it is either banned or moved, I had all the data entered and all the information about the computer and the bios files, I don't know how to publish, thank youComment
You have already posted your request at post #10, the bios and info is there. All you had to do was post the word bump,you did not have to make a new thread.
Anyway,the serial number should be on a sticker on the bottom case,we have the short toshiba part number though "PSCGNE" so someone should be able to help .
.Comment
by SMDFleaCommon SPI bios chip programming Questions and Answers
Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
A: If you can`t read from it how do you expect to write to it ?.
Q: Why is my bios chip unreadable ?.
A: The programmer is faulty or has a worn or broken zif socket.
The USB cable is frayed,connector pins worn or some other physical damage.
Not enough amperage or voltage to power the programmer properly.
Bad...-
Channel: BIOS Requests ONLY!
09-02-2021, 04:40 PM -
by macabookHello everyone,
07-24-2025, 02:17 PM -
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
