DA0U82MB6D0 Bios & EC Files
  • sriram
    • Dec 2017
    • 6
    • India
    Re: Need Bios Dump HP 15-n234sl BID 02165
    Originally posted by Simpletek
    Need bios dump for hp 15-n234sl Board ID 02165, from hp site the bios is encrypted, thanks.
    Need 15 N U82 BIOS Programming
    • sriram
      • Dec 2017
      • 6
      • India
      Originally posted by Ramee
      What is the motherboard code?
      need hp 15-N U82 bios programming
      • anooluk
        • Nov 2014
        • 5
        • thailand
        Re: Need Bios For DA0U82MB6D0 Rev D
        thank qqq
        • mohammed mohan
          • Nov 2017
          • 196
          • z
          Hi I hope you need help file hp 15-n009se bios
          DA0U82MB6D0 REV.D
          thank you
          Mohammed Mohan
          • sourcebf
            • Jul 2016
            • 431
            • N/A
            Re: Hi I hope you need help file hp 15-n009se bios
            Try form HP official web site....
            • mohammed mohan
              • Nov 2017
              • 196
              • z
              #26
              Thank you my friend but I tried the files and the device did not work
              The old programming file works but does not display Is there a solution Thank you
              Mohammed Mohan
              • sourcebf
                • Jul 2016
                • 431
                • N/A
                #27
                post your backup please..
                • mohammed mohan
                  • Nov 2017
                  • 196
                  • z
                  #28
                  Unfortunately the file is lost
                  Mohammed Mohan
                  • polytek
                    • Dec 2013
                    • 496
                    • TUNISIA
                    #29
                    here you go:
                    • mohammed mohan
                      • Nov 2017
                      • 196
                      • z
                      #30
                      Thank you . I tried the file unfortunately the device did not work
                      Mohammed Mohan
                      • polytek
                        • Dec 2013
                        • 496
                        • TUNISIA
                        #31
                        the bios file was tested, and it's ok, check if you have touched a resistor around the bios chip.
                        • mohammed mohan
                          • Nov 2017
                          • 196
                          • z
                          #32
                          Mohammed Mohan
                          • mohammed mohan
                            • Nov 2017
                            • 196
                            • z
                            #33
                            Thank you for replying . I made sure the resistor around the chip is no problem. But I'm sure the problem is in the Bios
                            But unfortunately lost the file
                            Mohammed Mohan
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              #34
                              Dear friend, I dont think its a bios issue. Sourcebf has given you hp official dumps and polytek says his dump is tested ok. Check with signals like 3V/5V/15vALW, pch_RSMRST, SLP S3/SLP S4/5V-3V RUN ,1.5V RUN ETC.
                              • rager007
                                • Feb 2016
                                • 106
                                • Usa
                                #35
                                thank you
                                • Layth
                                  • 29
                                  • iraq
                                  #36
                                  thanks
                                  • aymanabodkika
                                    • Oct 2016
                                    • 25
                                    • egypt
                                    #37
                                    thank you
                                    • Zaraki7777
                                      • Sep 2017
                                      • 173
                                      Re: HP 15-n015st - DA0U82MB6D0 Bios & EC Files
                                      • fraig
                                        • Nov 2014
                                        • 36
                                        • cairo
                                        #39
                                        thanks
                                        • ravi_1617
                                          YY Solutions
                                          • Jan 2012
                                          • 345
                                          • India
                                          #40
                                          HP 15-n204ex - i5-NVidia
                                          MB : DA0U82MB6D0
                                          Board don't start . Until i clear Cmos ,remove main battery too.after that it works fine . Till i shut down . updated bios from HP site.
                                          still same problem .
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • haitham sharabati
                                            [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                            by haitham sharabati
                                            Hello engineers 😀,
                                            I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                            🔧 Device Info:
                                            - Model: HP 15-da2007ne
                                            - Product Number: 8XF55EA#ABV
                                            - Serial Number: CND0338P0D
                                            - CPU: Intel Celeron N4000
                                            - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                            💀 Problem:😅
                                            - Device shows “Administrator Password”...
                                            Today, 04:54 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • DynaxSC
                                            by DynaxSC
                                            11-17-2023, 10:56 AM
                                          • MDSI
                                            HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                                            by MDSI
                                            I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                                            Details:
                                            Model : HP OMEN 17-an012nf
                                            Motherboard Part Number : DAG3BAMBAF0 REV : F
                                            Serial Number (S/N) : 5CD7280D51
                                            BIOS chip : Winbond W25Q64VSIQ
                                            Programmer : EZP2023+
                                            Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                                            I already...
                                            07-28-2025, 07:11 AM
