need bios lenovo yoga 300-11lbr
  • roxboy1984
    • Jan 2022
    • 183
    • South Africa
    #41
    Re: Lenovo Yoga 300 11IBR seems to boot but No display
    Originally posted by hoaca388
    The file in the link Peste posted is suitable for your device, if your device is not working it means it is having another error, not the bios.
    For some cheap programmers, writing and reading the chip through a clip sometimes gives inaccurate results.
    ok thanks i shall remove the chip from the board and rewrite not using the clip. I didnt get any errors when using the clip though. not sure if that makes any difference.
    • roxboy1984
      • Jan 2022
      • 183
      • South Africa
      #42
      redid the chip off the board and still no luck. anyone have any other suggestions? thanks
      • hoaca388
        Badcaps
        • Jan 2022
        • 12432
        #43
        Try to test the display with an external monitor via the HDMI port.
        • roxboy1984
          • Jan 2022
          • 183
          • South Africa
          #44
          No Display on external monitor either.
          • roxboy1984
            • Jan 2022
            • 183
            • South Africa
            #45
            So for some reason when i now try and flash the bios chip i keep getting verification errors. I erase the chip and that completes successfully and then when i either try write the new bios or check to make sure its blank i get verification errors. Does anyone have any ideas? thanks
            • roxboy1984
              • Jan 2022
              • 183
              • South Africa
              #46
              No matter what i try i get "Verification error on address: 0x0000736D, Device: 0xFD" anyone have any ideas?
              • VictorAntunes
                • Apr 2021
                • 7
                • Brazil
                #47
                Re: need bios os lenovo yoga 300-11lbr
                Has anyone managed to solve the keyboard and touchpad problem not working?
                • roxboy1984
                  • Jan 2022
                  • 183
                  • South Africa
                  #48
                  Please can someone help. I have a Lenovo Yoga 300, board model is IT-158TC. The machine seems to boot but I get no display. I've tried flashing multiple Bios's from the forum but still no luck. please can someone advise what else I can try?
                  Attached is the Original Bios + EC.
                  • peste
                    • Dec 2016
                    • 13891
                    • ROMANIA
                    #49
                    if post #21 doesn't work, you have another problem, provided you wrote the bios without errors..
                    • rui4892
                      • Mar 2017
                      • 57
                      • Portugal
                      #50
                      Re: need bios lenovo yoga 300-11lbr
                      hello forum
                      Can somebody post pinout for kbc to read EC with svod1... thanks.
                      • p0stman
                        • Mar 2016
                        • Spain
                        #51
                        Hi folks!
                        Could someone solve the touchpad and keyboard issue?
                        I've tried all the bios images inside this thread but I get the same problem.
                        Thank you.
                        • Hraff
                          • Dec 2018
                          • 23
                          • morroco
                          #52
                          hi everyone. I need to clear the password from this lenovo Bin file, thanks in advance
                            • 22233
                            Type the laptop serial number, full name and model, motherboard model, etc.
                            read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
                            • Hraff
                              • Dec 2018
                              • 23
                              • morroco
                              #54
                              thank you, i fix it up.
                              • to5it0
                                Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                                by to5it0
                                Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                                I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                                This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                                I have opened the laptop and identified the main BIOS chip...
                                10-24-2025, 01:35 AM
                              • maeson
                                BIOS Request - Lenovo Yoga L13 Gen3 (AMD)
                                by maeson
                                Hi dear Badcaps-Community,
                                Somehow an auto update, which I triggered before I left my laptop unattended, bricked my BIOS.
                                I was able to extract the 2MB BIOS and 16MB BIOS which I will attend. (CH341B black with NeoProgrammer 2.2.0.10)
                                The Device is a Lenovo Yoga L13 Gen3 and I was able to identify the following specifications:
                                Lenovo Yoga L13 Gen 3 AMD:
                                Lenovo Modell: Type 21BB
                                Artikelnr.21BB006GGE
                                Seriennummer: PW0A6207
                                AMD Ryzen™ 5 PRO 5675U
                                Memory 16 GB DDR4-3200MHz
                                SSD: 512 GB SSD, M.2 2242, PCIe Gen4, TLC,...
                                10-31-2025, 03:08 AM
                              • x52xx
                                Lenovo yoga 7 ARB7 bios bin file
                                by x52xx
                                Hi, All
                                BIOS upgrade brick, Need bin file to flash.
                                Model: Yoga 7 ARB7
                                SN: PF3XNA16
                                bios file link:
                                https://newdriverdl.lenovo.com.cn/ne...S-K5CN42WW.exe
                                08-19-2024, 06:13 AM
                              • Forest79
                                by Forest79
                                However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                07-23-2023, 07:39 AM
                              • survivalbloke
                                Unable to extract bios file from Lenovo bios exectuable
                                by survivalbloke
                                I'm trying to extract a flashable bios file(ch341a) from the lenovo bios executable download. I have tried the instructions from this site https://starkeblog.com/lenovo/uefi/2...pdate-exe.html, which are not working. According to those instructions, after issuing the command
                                Code:
                                "innoextract 7wcn38ww.exe"
                                it should create an \app folder, inside which, I should find a newly created "7wcn38ww.exe" file. I should then be able to extract that using 7zip and find my .FD file.
                                The trouble I'm having is that I'm not getting the newly...
                                06-12-2024, 07:55 AM
