Lenovo g50-70 bios problem
  • bollin
    • Mar 2013
    • 104
    • Finland
    Hello.
    I recently got this laptop from a friend. It would not boot, but as I did some initial troubleshooting I saw that the screen was coming on and off. So I flashed the bios with rom from this thread:
    https://www.badcaps.net/forum/showthread.php?t=48851
    It now works, but it starts very slowly until the lenovo logo is displayed. I am also unable to update bios to latest version (9acn32ww, current version is 9acn25ww) from lenovo website. It uses Insydeh20 and it always displays firmware update error, I have tried in legacy mode, uefi mode, disable secureboot a.s.o but nothing.
    It also reads in the bios setup that it have no DPK (Digital Product Key), is that lost too or is it because I have installed win 8.1 pro instead of 8 retail?
    I have saved the old corrupt bios image.
    Anybody else had problems like this?
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    Re: Lenovo g50-70 bios problem
    I have the same issue on some HP, I'm studying the problem and waiting a EC programmer to do some tests.
    • bollin
      • Mar 2013
      • 104
      • Finland
      Here is a guide to flash it in DOS mode.
      https://forums.lenovo.com/t5/Welcome...nt/ta-p/278406
      I haven“t tested that yet, but as soon as i get it tested I will report back how it went.
      • bollin
        • Mar 2013
        • 104
        • Finland
        Ok, so the DOS thing got me nowhere. I just got the same error message as described in the link.
        So, Next step was to try recovery flash. I used andy“s tool to get the filename, copied it to a formatted usb drive, pulled the battery and ac cord. press fn + r, insert AC and press power. It starts to read from the usb drive, but the reboots and no progress. Is it possible to edit the working dump to match EC (I assume that is the problem, EC and UEFI doesn“t match)?
        • bollin
          • Mar 2013
          • 104
          • Finland
          I managed to extract bios binary from .fd file found in lenovo executable (I think)
          The extracted binary is the same size as the dump. Doesn“t that mean that when flashing some data is copied from old bios to new when flashing? Like S/N and SLP key? Otherwise I cannot understand why the working dump from the other thread didn“t work properly.
          So, Next I“m going to try to remove IC, solder in cable with connector that fits an adapter with SOP8 & my programmer and program in working bios. Boot it up to recovery menu, pull IC and program original bios to it and flash new bios from lenovo using flashit (DOS mode). Any thoughts on that?
          • jasko_jacker
            • Oct 2014
            • 1137
            • italy
            Dos mode with fpt or similar software is not the best choice in this situation.
            Desolder the chip, reprogram with bios dump and resolder it , but there are other things , this model has a programmable EC and I think there is a problem regarding his firmware.
            I think it is so slowly because there is a check on some data as serial number inside new bios and the original factoring data stored (I think) in the EC .
            • bollin
              • Mar 2013
              • 104
              • Finland
              Problem solved!
              I opened up my corrupt bios rom file in UEFI tool, and noticed that there was a part that could not be decompressed. So I replaced that section with a body from working dump. Programmed it and now it works! Serial number is correct, UUID, windows license etc.
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3578
                • slovakia
                nice
                • kiraro
                  • Jan 2016
                  • 177
                  • North NY
                  Originally posted by bollin
                  Problem solved!
                  hello sir,
                  i have the same problem, and i flash the bios with another file it works great but logo lenovo appear after 20 seconds , i attached here my original backup and the working file, if you can fix my original bios? thank you so much .
                  • bollin
                    • Mar 2013
                    • 104
                    • Finland
                    Sorry, I have been away for a while. Try this!
                    • nova100
                      • Feb 2017
                      • 35
                      • Egypt
                      i have same laptop and the issue that it works fine with charger but when i attach the battery it give me (power on and no display).by removing the battery it is fine and normal .so any one have an idea abut this problem .thanks
                      • newarcada_computers@yahoo
                        • Jan 2019
                        • 25
                        • Romania
                        Re: Lenovo g50-70 i3 bios problem
                          • Jan 2019
                          • 25
                          • Romania
                          Problem solved, biso dump no delay logo lenovo
                          • madrali
                            lenovo e15 gen2 bios ? problem
                            by madrali
                            Model: Lenovo ThinkPad E15 Gen 2 (Intel)
                            20TD-50S0KU00
                            Hi, my laptop suddenly shut down while it was running. When I try to turn it back on, the screen stays black and it emits a melodic beep.
                            I used Lenovo's SmartBeep decoder and it returned error 0284:
                            "TCG-compliant functionality-related error (possibly BIOS code validation failure)"
                            I then tried to enter crisis BIOS recovery mode by pressing Fn + R at boot. The melodic error code changes, but nothing else happens regardless of whether a USB is inserted. I receive another...
                            06-16-2025, 12:06 PM
                          • AquaMan Ua
                            by AquaMan Ua
                            05-17-2025, 09:40 AM
                          • jendkkd jeje
                            Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                            by jendkkd jeje
                            So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                            I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                            10-11-2024, 03:12 PM
                          • mximiliandz
                            help bios lenovo ideapad s145-14iil type 81w6
                            by mximiliandz
                            Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                            06-20-2025, 06:50 AM
                          • konradx
                            Lenovo Thinkpad T15 Touchscreen problem bios
                            by konradx
                            i have problem witch Lenovo T15, my LCD display was demaged, i buyed New LCD, Touch screen version. Problem is LCD Working but Touchcreen not working, i wrinted to seller . He sended to me another LCD, but still not working. I have to Lenovo T480s with touchcreen LCD and that display and touch work. I think that is somethink like whitelist support LCD in BIOS. Someone have the same problem?
                            That is my DUMP.
                            My device:
                            SN: PF29Y4N6
                            1s20S7S2WF00PF29Y4N6
                            MB: GT4A0 GT5A1 GP4A0 GP5A1 GT4A2 NM-C931 REV 1.0...
                            09-06-2024, 01:33 AM
