Need Bios dump for Asus X70AB MB ver: K70AB
  • the_strom
    • Oct 2016
    • 6
    Need Bios dump for
    Asus X70AB
    MB ver: K70ab
    X70AB-TY049V
    thanks
  • warshin
    • Feb 2015
    • 13
    • syria
    Re: Need Bios dump for Asus X70AB MB ver: K70AB
    from asus site
    • mkdj
      by mkdj
      Dear all,
      10-19-2025, 04:41 AM
    • razor_amd
      by razor_amd
      12-15-2020, 07:07 PM
    • pirati
      by pirati
      10-27-2025, 04:20 PM
    • DynaxSC
      by DynaxSC
      06-14-2024, 03:49 PM
    • Ahari
      by Ahari
      I...
      08-13-2025, 06:12 AM
