LA-A996p rev:4.0 dump
  • quic307
    • Jun 2015
    • 255
    • Greece
    I need bios dump for LA-A996p rev:4.0.
    I have the old bios (8MB).
    Does anyone have it?
  • imranromi
    • Jan 2015
    • 1288
    • Pakistan
    Re: LA-A996p rev:4.0 dump
    try this and reply.
    • quic307
      • Jun 2015
      • 255
      • Greece
      Thank you but I have same problem.
      Probably kbc problem....
      • smali
        • Sep 2014
        • 287
        • Pakistan
        whats the problem?
        • highpulse
          i hate HP
          • May 2013
          • 1488
          • portugal
          does boards have a common problem with SUSP command , and major part of does that enter the lab here , have issues wiith KBC , after rewriting KBC usually all is fine after.
          somethimes require its replacement.
          but firstt oof all wich are the issues you are feeling?
          • quic307
            • Jun 2015
            • 255
            • Greece
            I have problem with kbc, I changed it and second problem with cpu.
            I give it back ...
            Thanks for help...
            • samuelnagy
              • Feb 2017
              • 16
              • Egypt
              • quic307
                • Jun 2015
                • 255
                • Greece
                Originally posted by samuelnagy
                Tell me if works fine???
                • Derach
                  • Jun 2017
                  • 8
                  • burkina faso
                  So thank, i have 1 question, i have thé same h15 protected with administrator passeword,i have try to flash bios after no display,this bios firmware Can resolve this?
                  • aday
                    • May 2016
                    • türkiye
                    la-a996p io please
                    • Pascal Komlassan
                      • Jan 2017
                      • 806
                      • TOGO
                      Originally posted by imranromi
                      try this and reply.
                      Good it's working
                      • burakdag
                        • Aug 2016
                        • 3
                        • Maltepe
                        test ok
                        • yoseef
                          Banned
                          • Aug 2019
                          • 9
                          • 88883656258
                          • yildirim05
                            • Mar 2015
                            • 11
                            • turkey
                            Thanks guys
                            • prypoy
                              • Jul 2019
                              • 3
                              • Украина
                              thank you
                              • rager007
                                • Feb 2016
                                • 106
                                • Usa
                                100% Test ok Org bios ...
                                • jimore
                                  • Nov 2020
                                  • 177
                                  • mexico
                                  Pls help no display bios..
                                  Here back-up thanks
                                  • jimore
                                    • Nov 2020
                                    • 177
                                    • mexico
                                    Originally posted by burakdag
                                    test ok
                                    thanks tested for me working 100%
                                    HP MODEL-15-G059WM ZS051-LA-A996P REV 4.0
                                    • nnph3
                                      • Aug 2014
                                      • nha trang
                                      Thank you so much !
                                      • adamgouadma
                                        • Jul 2017
                                        • 183
                                        • setif
                                        Thank
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          Today, 05:12 AM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • MDSI
                                          HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                                          by MDSI
                                          I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                                          Details:
                                          Model : HP OMEN 17-an012nf
                                          Motherboard Part Number : DAG3BAMBAF0 REV : F
                                          Serial Number (S/N) : 5CD7280D51
                                          BIOS chip : Winbond W25Q64VSIQ
                                          Programmer : EZP2023+
                                          Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                                          I already...
                                          07-28-2025, 07:11 AM
                                        • grimacelord
                                          Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                                          by grimacelord
                                          This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                                          Motherboard model number: DA0PAMB46A1 REV: A
                                          Secondary motherboard model number: 0PAB
                                          SKU: 685K4UA
                                          Serial number is: 5CD3223BJP
                                          Recently reflashed this laptop with latest BIOS and once...
                                          05-07-2024, 08:06 AM
