Toshiba L55-B5267 Bios
  • bluestone
    • Jun 2011
    • 343
    • Ghana
    I need dump for this Board da0blimb6f0
  • bluestone
    • Jun 2011
    • 343
    • Ghana
    Re: Toshiba L55-B5267 Bios
    I have been able to extract from update file, 100% working
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      thank you, it is 100% working, just tested it
      Im Back... sort of...
      • Ahari
        by Ahari
        I...
        08-13-2025, 06:12 AM
      • mkdj
        by mkdj
        Dear all,
        10-19-2025, 04:41 AM
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
      • haitham sharabati
        by haitham sharabati
        Hello engineers 😀,
        🔧 Device Info:
        - Model: HP 15-da2007ne
        - Product Number: 8XF55EA#ABV
        - Serial Number: CND0338P0D
        - CPU: Intel Celeron N4000
        💀 Problem:😅
        08-07-2025, 04:54 AM
      • DProf.
        TOSHIBA DYNABOOK T55/AB, PT55ABP-BJA2 BIOS DUMP
        by DProf.
        High great minds, please i need bios dump for this system .or help to REMOVE the PASSWORD in my original dump
        Toshiba Dynabook T55/AB, PT55ABP-BJA2
        MODEL NAME. Satellite L50-D series
        P[ART NO PS57MN-00600R
        Attached is my original bios dump ADMIN. PASSWORD LOCKED. Thank you in advance....
        09-26-2024, 04:30 AM
