Apple Macbook Pro A1278 BIOS Dump
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
Re: Apple Macbook Pro A1278 BIOS Dump
Hello. Help me remove the BIOS password macbook a1278 emc 2554Attached FilesComment
Try and write back.Attached FilesComment
Hello Everyone !
need to unlock this bios
Macbook pro A1278 820-3115-b
thanks in advanceLast edited by b tech; 01-11-2024, 10:01 AM.Comment
Read the rules before posting
https://www.badcaps.net/forum/troubl...11#post1843211
HELLO EVERYONE! I HAVE CLEANED PASSWORD OF MAC PRO A1278 820-3115-b 2010, AFTER THIS, DOESNT POWER ON, IM USING NEO PROGRAMMER AND THE CHIP IS MICRON 25Q064A, OTHER SOFTWARE LIKE CH341A DOESNT RECOGNIZE THE CHIP, IM USING CH341A ADAPTER. CAN YOU HELP ME PLS, HERE ITS THE ORIGINAL FILE.Attached FilesComment
bumpComment
Post the laptop serial number,and do not post in ALL CAPS please !!!
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
put back the original bios ... see if it starts againHELLO EVERYONE! I HAVE CLEANED PASSWORD OF MAC PRO A1278 820-3115-b 2010, AFTER THIS, DOESNT POWER ON, IM USING NEO PROGRAMMER AND THE CHIP IS MICRON 25Q064A, OTHER SOFTWARE LIKE CH341A DOESNT RECOGNIZE THE CHIP, IM USING CH341A ADAPTER. CAN YOU HELP ME PLS, HERE ITS THE ORIGINAL FILE.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
i have put back the original bios but doesnt start, only shows charger green power led and cooler turns on and stop again, I have tryed more than 10 differents bump with the same resultComment
try..Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
My macbook has a black screen after I deleted the efi password, the indicator light is white and the fan rotates normally but not fast, I have tried to replace the RAM but still the black screen does not change. Is there anyone who can help me?Comment
can someone help me if this bios get corrupted a1278 2012 just chime and fan spins fast but wont boot
ahm by the way i already replace the 980 YFC
thank you for any help heres the bios
a1278-emc2554
s/n CPWN683SDTY3Attached FilesComment
hello
plz i need to unlock this dump for macbook pro A1278Attached FilesComment
by AhariHi all,
I...-
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
Hello engineers 😀,
I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
- EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
by CityminHi all,
S/N : 5RNK9FFT70...-
- Loading...
