Apple Macbook Pro A1278 BIOS Dump
Every donation made will go towards server fees and maintenance costs.Comment
Re: Apple Macbook Pro A1278 BIOS Dump
post the original bios
https://www.badcaps.net/forum/showthread.php?t=103570Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
I extracted this bin file from my EFI chip, Thank you!post the original bios
https://www.badcaps.net/forum/showthread.php?t=103570Attached FilesComment
try..Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
thank you Peste, I have a quick question. My MacBook is early 2011 I was forgot my bios password and ordered a new chip from Ebay I soldered on board, password cleared but I have a EFI sleep wakeup problem, fan spin very fast but won't turn ON, Sometimes I tried to reset the SMC but only 2 or 3 times was successful this method.
I import your bin file into the Ebay's chip, but nothing happened. (Won't turn ON, Fan spin very fast)
any Solution?
Thanks,Comment
Trythank you Peste, I have a quick question. My MacBook is early 2011 I was forgot my bios password and ordered a new chip from Ebay I soldered on board, password cleared but I have a EFI sleep wakeup problem, fan spin very fast but won't turn ON, Sometimes I tried to reset the SMC but only 2 or 3 times was successful this method.
any Solution?
Thanks,
A1278 2012 EFI LOCK
who can help me?
25L6406E
readed with asprogrammer, tnxAttached FilesComment
pls help me remove password.Attached FilesComment
try..Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
hi
i have this dump from MacBook pro A1278 locked , i Need clear password thanksAttached FilesComment
try,..Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Can you please remove bios password?Attached FilesComment
Izvolte/Here you go.Attached FilesI don't provide help for people using CH341A and a clip.Comment
			by AhariHi all,
I...-
			by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
							Channel: BIOS Requests ONLY!
			by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
			Hello engineers 😀,
I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
- EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
			by CityminHi all,
S/N : 5RNK9FFT70...-
 - Loading...
 I hope the sleep-wakeup problem is solved. I will work with it and update the result here.
