hp 15 bios da0u93mb6d2
  • bluestone
    • Jun 2011
    • 343
    • Ghana
    I need this dump urgently pls help da0u93mb6d2
  • imranromi
    • Jan 2015
    • 1288
    • Pakistan
    Re: hp 15 bios
    Try this and reply.
    • bluestone
      • Jun 2011
      • 343
      • Ghana
      Re: hp 15 bios
      Originally posted by imranromi
      Try this and reply.
      already tried this one it didn't work. this is for da0u93mb6d0
      • mehmood muhaish
        • Sep 2013
        • 37
        • pakistan
        Re: hp 15 bios
        need bios DA0U93MB6D2 REV
        • ADAN
          • Apr 2017
          • TUNISIA
          Re:HP 15 BIOS
          • fyaagoub
            • 269
            • maroc
            Re: hp 15 bios
            Thank you very much
            • Watz
              • Sep 2014
              • 21
              • Kenya
              Re: hp 15 bios
              Thank you, worked like a charm on a DA0U93MB6D2 board
              • premnam@gmail.com
                • Apr 2015
                • india
                not working ..i tried this
                • samoosa
                  • Jan 2015
                  • South Africa
                  Re: hp 15 bios
                  How do I read/write ec chip?
                  • hussaka
                    • Jan 2015
                    • 152
                    • italy
                    Re: hp 15 bios
                    thank you so much
                    • eljiranih
                      • May 2020
                      • maroc
                      Re: hp 15-ay011tx bios
                      thank you so much
                      • Habble7
                        by Habble7
                        Suspected Cause:
                        Troubleshooting Attempts:
                        05-22-2025, 07:28 AM
                      • DynaxSC
                        by DynaxSC
                        11-17-2023, 10:56 AM
                      • MDSI
                        HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                        by MDSI
                        I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                        Details:
                        Model : HP OMEN 17-an012nf
                        Motherboard Part Number : DAG3BAMBAF0 REV : F
                        Serial Number (S/N) : 5CD7280D51
                        BIOS chip : Winbond W25Q64VSIQ
                        Programmer : EZP2023+
                        Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                        I already...
                        07-28-2025, 07:11 AM
                      • grimacelord
                        Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                        by grimacelord
                        This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                        Motherboard model number: DA0PAMB46A1 REV: A
                        Secondary motherboard model number: 0PAB
                        SKU: 685K4UA
                        Serial number is: 5CD3223BJP
                        Recently reflashed this laptop with latest BIOS and once...
                        05-07-2024, 08:06 AM
                      • DynaxSC
                        Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                        by DynaxSC
                        I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                        It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                        I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                        11-06-2022, 05:22 PM
