Help.. I need bios dump for ASUS TP500LN REV: 2.0
  • bios
    • Nov 2014
    • 64
    • Philippines
    Can anyone help me, I need bios dump for ASUS TP500LN REV: 2.0
    Thank you.
  • highpulse
    i hate HP
    • May 2013
    • 1488
    • portugal
    Re: Help.. I need bios dump for ASUS TP500LN REV: 2.0
    here mate
    • bios
      • Nov 2014
      • 64
      • Philippines
      Thank you.
      • bios
        • Nov 2014
        • 64
        • Philippines
        Thank you highpulse, I tried it and it works.
        • highpulse
          i hate HP
          • May 2013
          • 1488
          • portugal
          cool to hear my friend
          • sherifbekhit
            • Feb 2017
            • 19
            • alex
            thank you too much
            • Mimazima
              • Jul 2017
              • 84983522348
              Originally posted by highpulse
              here mate
              thnks
              Sante des femmes www.viagrasansordonnancefr.com avantages des medicaments
              • mahmoodjavan
                Banned
                • Mar 2018
                • 584
                • iran
                Originally posted by bios
                can anyone help me, i need bios dump for asus tp500ln rev: 2.0
                thank you.
                plz test
                • Longmam
                  • Nov 2014
                  • 15
                  here mate
                  It is a good one. It can work.
                  • birol06
                    • Jan 2017
                    • 15
                    • türkiye
                    thank you
                    • jevakin
                      • Oct 2021
                      • Turkey
                      !!!! working !!!
                      • meshuksaha
                        • Jun 2022
                        • Bangladesh
                        • hardware1
                          • Sep 2021
                          • 2925
                          • N/A
                          Upload your Original Backup and write your device Serial Number.
                          all donations are welcome,
                          • teratron
                            ahuhu
                            • Dec 2022
                            • 31
                            • Việt Nam
                            here mate
                            thanks you, its work, but slow on, about 30s screen on
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 11614
                              https://www.badcaps.net/forum/showpo...41&postcount=3
                              • razor_amd
                                by razor_amd
                                12-15-2020, 07:07 PM
                              • DynaxSC
                                by DynaxSC
                                06-14-2024, 03:49 PM
                              • Habble7
                                by Habble7
                                Suspected Cause:
                                Troubleshooting Attempts:
                                05-22-2025, 07:28 AM
                              • Anchar777
                                ASUS P1412CE need BIOS DUMP
                                by Anchar777
                                Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
                                06-26-2025, 03:39 AM
                              • kcp0085
                                Request BIOS dump for ASUS FA617NS-A16.R77600
                                by kcp0085
                                Aloha, I'm trying to recover my ASUS TUF Gaming A16 (FA617NS-A16.R77600)
                                I have the CH341A programmer and can flash the BIOS chip directly. I need a verified full .bin dump (2MB or full SPI region) for this specific model.
                                Specs:
                                - ASUS TUF FA617NS-A16
                                - CPU: AMD Ryzen 7
                                - BIOS chip: Winbond W25Q16JVSIQ (2MB)
                                If anyone has a full dump or can share from a working unit, it would be hugely appreciated.
                                Thanks in advance!​
                                05-02-2025, 12:52 AM
