Asus X455L BIOS dump please
  • subroto
    • Oct 2015
    • 230
    • Bangladesh
    Help me guys.
    I need Asus X455L BIOS dump.
    Motherboard code:
    ASUS X455LD
    (60NB06A0-MB1320)
    REV 2.1
    Thanks in advance.
  • subroto
    • Oct 2015
    • 230
    • Bangladesh
    Asus X455L i3 BIOS dump
    Help me guys.
    Motherboard code:
    ASUS X455LD
    (60NB06A0-MB1320)
    REV 2.1
    Thanks in advance.
    • subroto
      • Oct 2015
      • 230
      • Bangladesh
      Asus X455L BIOS please
      Help me guys.
      Motherboard code:
      ASUS X455LD
      (60NB06A0-MB1320)
      REV 2.1
      Thanks in advance.
      • ridamouh159
        • Nov 2014
        • 365
        • maroc
        Re: Asus X455L BIOS please
        Try withe this dump
        • subroto
          • Oct 2015
          • 230
          • Bangladesh
          Originally posted by ridamouh159
          Try withe this dump
          Thanks a lot bro. I'll try soon.
          • rodrijito
            • Nov 2016
            • 5
            • argentina
            Re: Asus X455L i3 BIOS dump
            hi download full bios for asus x455l
            https://1drv.ms/u/s!AqvJOCow-p_1uW6cs5dgo7PEQBuv
            • qonma
              Kuli Solder
              • Jun 2017
              • 185
              • INDONESIA
              Re: Asus X455L BIOS dump please
              Originally posted by subroto
              help me guys.
              I need asus x455l bios dump.
              Motherboard code:
              Asus x455ld
              (60nb06a0-mb1320)
              rev 2.1
              thanks in advance.
              • subroto
                • Oct 2015
                • 230
                • Bangladesh
                Thanks Bro...
                • subroto
                  • Oct 2015
                  • 230
                  • Bangladesh
                  Asus X455L Working BIOS
                  Here Asus X455LD Rev 2.1 working BIOS for you all...
                  • kadi144
                    • Aug 2015
                    • 690
                    • algerie
                    Re: Asus X455L Working BIOS
                    THANKS MR .subroto
                    • winpinph
                      • Jun 2018
                      • 9
                      • philippines
                      I need X455LJ MAIN BOARD
                      REV 3.1
                      bios please
                      I notice there are lots of asus x455l model will the bios work for all asus x455l with L_D_J models?
                        • 22283
                        REV 3.1
                        bios please
                        Try the one here: https://www.badcaps.net/forum/showthread.php?t=69148
                        • Duo Ahmad
                          • Sep 2021
                          • Indonesia
                          Super support Flash with CH341A, EZP2019 Bios Asus Chipset Core i3 X455L, X455LA Rev.2.1 Board, 202 series, MXIC MX25L6473E Macronix bios ic series:
                          https://www.mediafire.com/download/o5f8dq4hujyjstj
                          • mkdj
                            by mkdj
                            Dear all,
                            10-19-2025, 04:41 AM
                          • razor_amd
                            by razor_amd
                            12-15-2020, 07:07 PM
                          • pirati
                            by pirati
                            10-27-2025, 04:20 PM
                          • DynaxSC
                            by DynaxSC
                            06-14-2024, 03:49 PM
                          • Ahari
                            by Ahari
                            I...
                            08-13-2025, 06:12 AM
