Bios HP 840 g1 - 6050A2560201-MB-A03
  • peste
    • 13924
    • ROMANIA
    #81
    Re: Need bios dump for HP elitebook 840 g1
    Originally posted by 3lsheikh
    Hi
    I try this backup and its working but no serial number, I have my old backup but it not turning the laptop up it's corrupted cane any one please help me with this I believe my nvme is valid but I can't merge it
    attached my old dump
    try..
    • 3lsheikh
      • Nov 2020
      • 6
      • Egypt
      #82
      unfortunately not turning on, Caps Lock blinking
      • peste
        • 13924
        • ROMANIA
        #83
        what model of motherboard do you have ???
        • 3lsheikh
          • Nov 2020
          • 6
          • Egypt
          #84
          Sorry i don't know which one is the motherboard version attached photos of the stickers
          • peste
            • 13924
            • ROMANIA
            #85
            it is written on the white paint plate.
            • 3lsheikh
              • Nov 2020
              • 6
              • Egypt
              #86
              I think it's : 730804-001
              • 3lsheikh
                • Nov 2020
                • 6
                • Egypt
                #87
                This one 6050A2560201-MB-A03
                • peste
                  • 13924
                  • ROMANIA
                  #88
                  try..
                  • 3lsheikh
                    • Nov 2020
                    • 6
                    • Egypt
                    #89
                    Originally posted by peste
                    try..
                    Thank you very much it's working fine now
                    • coty49
                      Coty
                      • Jul 2017
                      • 6
                      • burkina faso
                      #90
                      Re: Hp 840 g1 - 6050a2560201-mb-a02
                      Originally posted by bilen
                      problem persists.
                      I think the Onboard CPU is faulty.
                      Hello, were you able to find a solution because I have the same problem. Thank you
                      • tinto
                        • Jul 2017
                        • 74
                        • serbia
                        #91
                        your bios chip is not good...i guess it's a winbond, take another chip and program it
                        • Jamescl
                          • Feb 2017
                          • 29
                          • Bangladesh
                          #92
                          thankz
                          • Genova
                            • Jan 2020
                            • 118
                            • FRANCE
                            #93
                            840 g1
                            I have two HP 840g1 with which I cannot get the bios with my CH341.
                            I tested, replaced everything (programmer, clip, cable, usb port...) and the result remains the same :
                            when i put the clip on the chip it the software it detected the good chip then no more connection on it
                            Detection fails could not find the chip with CH341A Programmer soft 1.30 or
                            1 fast small blink then completely yellow led on ch341 with asprogrammer
                            whether I put the power on or not same thing...
                            Chip is Winbond W25Q128FV
                            Any idea on this problem ?
                            • peste
                              • 13924
                              • ROMANIA
                              #94
                              Re: 840 g1
                              do not use the clip..draw wires from the chip to the programmer if you cannot remove the chip from the motherboard ... use one of these programs ..
                              https://www.badcaps.net/forum/showpo...6&postcount=10
                              https://www.badcaps.net/forum/showpo...04&postcount=7
                              • Genova
                                • Jan 2020
                                • 118
                                • FRANCE
                                #95
                                Re: 840 g1
                                Thank you will try this
                                • Genova
                                  • Jan 2020
                                  • 118
                                  • FRANCE
                                  #96
                                  Re: 840 g1
                                  it does the same, and when I get to connect to read and save the files they are not the same...
                                  What type of wires do i need to buy ?
                                    • 22279
                                    Re: 840 g1
                                    Attach the charger to the board after attaching the wires
                                    https://www.badcaps.net/forum/showpo...6&postcount=51
                                    • Genova
                                      • Jan 2020
                                      • 118
                                      • FRANCE
                                      #98
                                      Re: 840 g1
                                      Thank you will try this also
                                      • Genova
                                        • Jan 2020
                                        • 118
                                        • FRANCE
                                        #99
                                        Re: 840 g1
                                        All it's ok but after waiting 2-3 min more with removing charger I was finally able to read the chip
                                        • Genova
                                          • Jan 2020
                                          • 118
                                          • FRANCE
                                          #100
                                          Re: 840 g1
                                          another one who just light on power led and nothing more...
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • mkdj
                                            by mkdj
                                            Dear all,
                                            10-19-2025, 04:41 AM
                                          • haitham sharabati
                                            by haitham sharabati
                                            Hello engineers 😀,
                                            🔧 Device Info:
                                            - Model: HP 15-da2007ne
                                            - Product Number: 8XF55EA#ABV
                                            - Serial Number: CND0338P0D
                                            - CPU: Intel Celeron N4000
                                            💀 Problem:😅
                                            08-07-2025, 04:54 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • DynaxSC
                                            by DynaxSC
                                            11-17-2023, 10:56 AM
