Need Bios Dump Asus X402CA
  • dmartins
    David M
    • Apr 2014
    • 197
    • Lisbon
    Hello ,
    I need dump for X402CA if possible ,
    Thanks in advance
  • samanthban
    • Feb 2014
    • 253
    • Sri lanka
    Re: Need Bios Dump Asus X402CA
    not checked try it
    sigpic
    • dmartins
      David M
      • Apr 2014
      • 197
      • Lisbon
      Its working ,
      Many thanks
      • moyo_27
        • Sep 2014
        • 23
        • morelia
        si funciona ya probado muchas gracias team
        • Af19
          • Aug 2015
          • 4
          • portugal
          work fine thanks
          • zurvanielle
            • Feb 2017
            • 137
            • Philippines
            thanks.....^_~ it works....^_~
            • hondaxr
              • Jun 2014
              • 21
              • portugal
              Thanks it worked for me
              • razor_amd
                by razor_amd
                12-15-2020, 07:07 PM
              • Ahari
                by Ahari
                I...
                08-13-2025, 06:12 AM
              • ArkzG
                [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
                by ArkzG
                Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
                What I currently have available:
                - Model: FA506NF (2021)
                - BIOS chip: GD25LQ16 (16Mbit/2MB)
                - Tools: CH341A programmer ready to use
                Does anyone have either a clean 2MB .bin dump of this model,...
                09-26-2025, 09:34 PM
              • kodox
                Asus ExpertBook B1400CB Bios Dump Needed
                by kodox
                need original bios dump, original bios has flashed by other technician before me.
                attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
                unit info:
                Model: Asus ExpertBook B1400CBA-0711A1235U
                S/N: R6NXNZ006657238
                CN: 7F6F
                Mainboard Code: B1500CBA R2.1...
                08-16-2025, 12:20 PM
              • Habble7
                by Habble7
                Suspected Cause:
                Troubleshooting Attempts:
                05-22-2025, 07:28 AM
