HP DV6 6C65el (MB Winstron 48.4RH09.021): split BIOS file to direct flash
  • Fulcro
    • May 2012
    • 12
    • Italy
    Hello. This notebook arrived dead. Tryied to reflash the SPI eprom with files of SIMILAR motherboard and it turned to life. Now I tryied to update BIOS downloading it from HP site, but the executable says "this bios is not for your computer" (I guess it depends by the current BIOS not perfectly compatible with the board..).
    I'm thinking to desolder the chips and reflash it with my programmer with the correct files, but the file provided by HP is a merged file containing either main bios and EC bios, and I haven't found the separated files for my model.
    So I need help: can I split the file in two single files and flash it separately?
    I don't want to leave the current bios because I cannot use the WIFi board, and there are some minor issue that I think are related with the wrong BIOS.
    If it can help, I attach the original damaged bios files, and the currentlt installed files, probably dedicated to the dv6-6b54er model.
    The file I have to split is contained in the archived file downloadable from HP site:
    http://ftp.hp.com/pub/softpaq/sp60501-61000/sp60655.exe
    Thank a lot for any help!
    Fulcro
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: HP DV6 6C65el (MB Winstron 48.4RH09.021): split BIOS file to direct flash
    welcome to forum
    bios for this board is strange to say at least
    in SP60655 there are two bios with same BID but thay are not the same so i cannt be sure which one is it so you must try both... thay are already latest version
    Im Back... sort of...
    • Fulcro
      • May 2012
      • 12
      • Italy
      Thanks a lot ala_borbe! In the HP_TOOLS partition of the notebook there's already a folder BIOSUpdate with the bin file which I think is the original version. Do you think that comparing the bin file with each one of the file contained in the archive from HP I can realize which version I have to flash of the files your provided?
      Moreover, what can I use to split future BIOS in Main and EC file?
      I tryied PhoenixTool (which works also with Insyde EFI BIOS), but seems a little more complicated for my current knowledge of the BIOS structure...
      Thanks a lot again!
      Fulcro
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        there is no generic way for that, nor tool cos its not the same every time, depends on construction of board and vendor
        at least i did not found any for for that, i do it manually with hex editor
        to help a bit:
        hp bios in most cases is encrypted meaning not readable content so the trick is to decrypt first... sometimes PhoenixTool can do this (in your case it can) that is the file with .dec extension
        sometimes it cannt but there are other methods for that
        finding where to cut big file is mostly easy if you have dump
        in big file do hex search to find where it starts, and size is known
        but in this case updated EC rom is 128k and eprom is 512k... simply pase 128k over bigger file, not touching the rest cos it wont turn on, it would be dead like horse
        now for serial part and dmi data... do search for text for model name and note adresses in hex and paste it to new bios at same address (in your case it 0x00180000 if i recall right)
        Using hex editor look at the end of bios and near end there would be BIDxxxx and that is how you can identify right bios
        i hope i made my self clear, and not to confusing
        • whitevolf
          • Feb 2014
          • 124
          • TÜRKİYE
          thanks
          • Wilfried
            • Sep 2019
            • 81
            • Cameroun
            hi i have an hp pavilion bv6
            when I start the keyboard flashes once and there is no display
            help me fix this bios file 🙏🏿 please
            • hardware1
              • Sep 2021
              • 2949
              • N/A
              Latest Version from HP, hope it works fine.
              all donations are welcome,
              • Wilfried
                • Sep 2019
                • 81
                • Cameroun
                Thank you brother but no picture
                I think it's the Radeon graphics that died
                • to5it0
                  by to5it0
                  10-24-2025, 01:35 AM
                • Citymin
                  by Citymin
                  S/N : 5RNK9FFT70...
                  08-05-2025, 05:12 AM
                • maanee11
                  Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
                  by maanee11
                  Hello Everyone,
                  I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
                  It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
                  In the website, you can only see specs etc.
                  I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
                  11-08-2025, 04:08 AM
                • m1ch43lzm
                  by m1ch43lzm
                  Hi everyone
                  09-06-2025, 05:47 PM
                • Forest79
                  by Forest79
                  07-23-2023, 07:39 AM
