Toshiba P70-A-104 bios request
  • lefos
    • Nov 2013
    • 321
    • Greece
    Hello everybody,
    I have this laptop with no picture problem and I think that the problem might be from BIOS. So I need your help if someone has a working dump.
    It has a GD25Q64 8mb chip, on toshiba's site the bios program is 8.35mb and it is impossible to reprogram it with this file.
    The motherboard code is da0bdbmb8f0. Please if someone has a dump to begin troubleshooting.
    Thank you in advance
  • lefos
    • Nov 2013
    • 321
    • Greece
    Re: Toshiba P70-A-104 bios request
    I attach below both the original and the one from toshiba's site.
    Thank you
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      try this, its cut down
      Im Back... sort of...
      • lefos
        • Nov 2013
        • 321
        • Greece
        Thanks a lot! Got picture and laptop works!
        So it as a 100% working dump for anyone interested.
        Thank you once again
        • maraketh
          • Jul 2017
          • 17
          hello everybody. can anyone help me with a dump for toshiba p70-b-10u? i looked everywhere
          • ghass
            • Apr 2014
            • 45
            • lebanon
            hi
            this is the file i test it
            • ravenmx
              • May 2018
              • 180
              • puebla
              thanks you your bios works
              • gizaha
                • Mar 2018
                • 25
                • Greece
                it work for me also.
                I had a toshiba satellite p70-a-129 with DA0BDBMB8F0, waked, no post.
                I made all known practices, it wasn't fixed.
                I wasn't sure for flashing because i had 3.3v at bios CS# pin and if i read correctly, that means bios ic is turned off.
                However flashing (and then clear cmos) fixed the problem.
                • gizaha
                  • Mar 2018
                  • 25
                  • Greece
                  Anyone has bios for p70-a-129? The bios i flashed from this thread does not recognize touchpad
                    • 22077
                    Post the laptop serial number and the short toshiba part number PSPLNx/PSPLPx ? , and your original bios backup.
                    • gizaha
                      • Mar 2018
                      • 25
                      • Greece
                      I was wrong, forget it.
                      The touchpad problem was from windows.
                      Thank you anyway (indeed is psplpX but the original bios is corrupted, i do not trust it)
                      • YvD-Electronics
                        Request BIOS files to flash Toshiba C55-A-1TX laptop
                        by YvD-Electronics
                        I need the BIOS (bin files) to re-flash the BIOS chips on a toshiba laptop.
                        Why I am pretty sure I need this to repair?
                        1) Power supplies seem OK.
                        2) Battery has been replaced, is charging well ... also not the CMOS battery CR2032, also not OK without RAM, or 1 or the 2 RAM modules (RAMS are OK).
                        3) Laptop does really rare (seems random things) with the 3 leds (power, net, ...)
                        4) In the past, when trying to restart 100 times via power button, it was sometimes succeeding, now no more.
                        08-09-2024, 10:05 PM
                      • jbonavita
                        by jbonavita
                        Some issues
                        Things I tried
                        04-29-2025, 09:38 PM
                      • zenius
                        by zenius
                        12-08-2024, 06:13 AM
                      • Wahaz
                        by Wahaz
                        10-30-2023, 08:42 PM
                      • aze2eza
                        [Request] BIOS Unlock for Toshiba Tecra X40-E-19
                        by aze2eza
                        I need help unlocking the BIOS of a Toshiba Tecra X40-E-19, Serial Number: 2K199216H.
                        The BIOS is locked (possibly password protected), and I have already dumped both the original BIOS and EC chips using an RT809H programmer.
                        Board model: FURRSY1 A4481A
                        I'm requesting assistance in removing the password or unlocking the BIOS while keeping system data intact.
                        Any help or patched file would be greatly appreciated.
                        Thank you!...
                        04-30-2025, 03:35 AM
