packard bell EG70BZ
Hello, I'm trying to update the BIOS (v2.04) of my Packard Bell EasyNote ENLE11BZ - E304G50Mnks Model EG70BZ, with Insyde H20 Rev. 3.7.
I tried some exe but the bios flash utility says is not compatible.
I found this thread, but I don't know how to flash these bin files.
Is there some advanced menu to unlock?
Many thanks to all.Comment
post S/N, full name and model, motherboard model, etc.Hello, I'm trying to update the BIOS (v2.04) of my Packard Bell EasyNote ENLE11BZ - E304G50Mnks Model EG70BZ, with Insyde H20 Rev. 3.7.
Many thanks to all.
post the contents of the bios chip even if it is corrupted..
The bios chip must be unsoldered from the board before writing or reading..
do not use the clip, you may have errors..if you do not have anything to unsolder it with,
solder wires between the programmer and the bios chip..
you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHowDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
by AhariHi all,
I...-
by maxlove70Hello, I'm searching Bios for Packard Bell iSTART 2356.
Asus for Packard Bell M2NS-NVM (Boston) 0206 BIOS - 6A69NA01
Manufacturer and model: Asus for Packard Bell M2NS-NVM (Boston)
Chipset: AMD 1100
Part number: 6A69NA01
BIOS ID: 03/05/2007-NF-MCP61-M2NS-NVM-00
BIOS Release date: 2007-03-05
BIOS Revision: 0206
Packard Bell Support for this PC is discontinued.
Please Help Me !!!!
Thanks.-
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
by DynaxSCHi,
Usually on ASUS boards it worked...-
- Loading...
