many bios corrupted !!!
  • Pragmatiko
    • Jul 2013
    • 468
    • IT
    Hi all, this last time i founding many bios corrupted on laptop.
    Whitch would be cause?
    Clients says never try to upgrade bios.
    Thank you.
  • tzoupkas
    • Jun 2014
    • 14
    • Greece
    Re: many bios corrupted !!!
    I also have the same question but as an electronic engineer I would say that the lack of differential mechanism, lack of error detection and correction mechanisms and higher bit rates can result to BIOS corruption but thats only theory (more precisely my theory). If anyone else has another opinion would be nice to share it here.
      • 31214
      serial flash seem pretty unreliable compared to the older parallel flash wih 28-32pins.
      • FalconPunch
        Surface Pro X 1876 Bios corrupted
        by FalconPunch
        Hello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
        Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...
        08-09-2025, 03:56 AM
      • macabook
        by macabook
        🧩 Initial Issue
        07-24-2025, 02:17 PM
      • TylerHyde21
        Lenovo TD350 ThinkServer BIOS v505 Corrupted BIOS,
        by TylerHyde21
        Hello, the bios on my Lenovo TD350 ThinkServer got corrupted during a bios update, the bios restore function killed the Server.
        I need to flash the bios inside the MX25L12835F SOP8, i have already desolder the chip and solder it into my SOP8 adapter and read it with a ROM programmer.
        I use the innoextract 1.9 software to extract the bios file from the .exe file that i download from lenovo website, can you help me edit the Hex file (removing the Index part and resize the file)?
        This guy claim to have done it https://forums.lenovo.com/t5/ThinkSe...doesnt-Start-u...
        06-29-2024, 10:38 AM
      • Loli Popu
        DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
        by Loli Popu
        Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
        12-13-2024, 08:29 AM
        by Vesko356
        08-11-2023, 03:27 AM
