POST ONLY ON BADCAPS
Dell 5559 bios
Device: Laptop
Brand: Dell
Model: Inspiron 5559 P51F004
Service Tag:HPTYBG2
Board number: aal15 la-d071p rev 1.0 (a00)
Original bios is attached, password is being requested on startup. Many thanks!!!Leave a comment:
Re: Dell 5559 bios
i try all files no one working with i 5 -with ati vga
this ont work good tested 100%Leave a comment:
Re: Dell 5559 bios
E7A8 suffix:
Requests for password removal or BIOS repair for which the method is available at BIOS guides, methods, resources and tools will not be tolerated anymore if you do not explain why you did not succeed.
.Leave a comment:
Re: Dell 5559 bios
can someone help me to erase password? EA78Attached FilesLeave a comment:
Re: Dell 5559 bios
no display in this bios , make it ok with clearme, thanks in advanceAttached FilesLeave a comment:
Re: Dell 5559 bios
Here's your Clean BIOS, try it.Attached FilesLeave a comment:
Re: Dell 5559 bios
Hello, can someone clear ME of this bios dump?Attached FilesLeave a comment:
Re: Dell 5559 bios
Re: Dell 5559 bios
Thanks sir,
i also succeded updating bios through bootable usb with dos command
Inspiron5459_190 /forceit
sir can u teach me in a simple way. how u did it plz???Last edited by OKRPKCOMP; 02-19-2023, 07:23 AM.Leave a comment:
Re: Dell 5559 bios
Re: Dell 5559 bios
Any solution to update it through usb or somebody can clean my bios???Leave a comment:
Re: Dell 5559 bios
Need bios repair Inspiron 5559
Service Tag: DXCLBG2
board code AAL15 LA-D071P REV 1.0
First display comes late and hangs or blue screen after 15 mints
old bios attachedLeave a comment:
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by jhanraHi there masters, recently i got a dell 5400 chromebook and wanted to install windows, i searched the internet and i found out other people also wanting a UEFI bios for this model, i searched there is a R/W legacy, but there are bugs like keyboard/trackpad not working, and hard to install.
in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...-
by gizahaDell latitude 5580, motherboard cdp 80 la-e151p
Since ssd is replaced and had clean install windows, i've... -
by mrrubikHi folks,
I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
Steps I took:- Read BIOS with CH341a, verified hash twice
- Patched
- Loading...
