Lenovo G505 bios dump needed
  • technician37
    • Aug 2018
    • 30
    • philippines
    #41
    Re: Lenovo G505 bios dump needed
    thank you
    • loko
      • Aug 2020
      • 29
      • croatia
      #42
      Originally posted by razor_amd
      Main file
      Thanks!
      • AMKAM11
        • Sep 2020
        • kenya
        #43
        thanks
        • O.Szilard
          • May 2019
          • 161
          • hungary
          #44
          Main file
          Thanks!
          • amirarbabi
            • Feb 2019
            • 34
            • usa
            #45
            Tnk you
            • Joluvillas
              Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
              by Joluvillas
              Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
              06-18-2024, 10:35 PM
            • AHmad_Salal
              Need BIOS Dump/ROM for Lenovo Thinkstation p500
              by AHmad_Salal
              Hello all,
              I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
              11-28-2023, 05:28 AM
            • DynaxSC
              by DynaxSC
              11-17-2023, 10:56 AM
            • TacticalFahrrad
              [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
              by TacticalFahrrad
              I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
              BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
              I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
              06-30-2025, 04:09 AM
            • hirens
              Lenovo ideapad 3 14IGL05 bios dump needed
              by hirens
              model: 81wh
              sn: pf36ta6h
              board no: nm-c961 gs453/gs553
              hey guys above is my laptop info
              it only blinks the power button kindly help me with a working dump
              old dump attached...
              07-21-2023, 04:48 AM
