Lenovo G505 bios dump needed
  • salawayon
    • Nov 2012
    • 573
    • philippines
    Info:
    VAWGA / GB LA-9911P
    REV: 1.0
    AMD CHIPSET
    No display problem.
    Thanks.
  • razor_amd
    • Sep 2013
    • 77
    • Serbia
    Re: Lenovo G505 bios dump needed
    This is dump for KBC chip
    • razor_amd
      • Sep 2013
      • 77
      • Serbia
      Main file
      • arisravi
        • Dec 2014
        • 20
        • india
        thanks great job
        • st33693
          • Aug 2012
          • 22
          • iran
          Tanks
          • Thunder1986
            • Feb 2015
            • 25
            • Hungary
            Thank you!
            • ghojariya abdul
              • Jul 2014
              • 39
              • india
              Thanks Bro...
              • ablehajaib
                • Feb 2017
                • indonesia
                Thx bro...
                • Pascal Komlassan
                  • Jan 2017
                  • 809
                  • TOGO
                  thanks bro
                  • dexx
                    • Dec 2013
                    • 18
                    • Philippines
                    can this work on me? i have same model of motherboard GB la-9912p rev: 1.0
                    but different lenovo model mine is g405
                    can i try this?
                    • Ali Elahmady
                      • Mar 2017
                      • Egypt
                      good
                      • techman1025
                        • Jun 2014
                        • 497
                        Hi dexx your model uses a different bin . Don't even think about using it . We could always upload your version bio if needed.
                        Techman1025
                        • samuelnagy
                          • Feb 2017
                          • 16
                          • Egypt
                          thank you
                          • najm
                            • Dec 2013
                            • iraq
                            thank you
                            • rewanco
                              • Nov 2015
                              • 21
                              • syria
                              Thank you!
                              • karem adil
                                • Oct 2016
                                • 37
                                • alex
                                Thank you!
                                • sherifbekhit
                                  • Feb 2017
                                  • 19
                                  • alex
                                  Originally posted by razor_amd
                                  Main file
                                  Thank you so much
                                  • sherifbekhit
                                    • Feb 2017
                                    • 19
                                    • alex
                                    Thank you so much
                                    • msl77
                                      • Jun 2014
                                      • 10
                                      • yemen
                                      • adysan
                                        • Jan 2017
                                        • 11
                                        Thank you!
                                        • Joluvillas
                                          Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
                                          by Joluvillas
                                          Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
                                          06-18-2024, 10:35 PM
                                        • AHmad_Salal
                                          Need BIOS Dump/ROM for Lenovo Thinkstation p500
                                          by AHmad_Salal
                                          Hello all,
                                          I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                                          11-28-2023, 05:28 AM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • TacticalFahrrad
                                          [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                                          by TacticalFahrrad
                                          I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                                          06-30-2025, 04:09 AM
                                        • hirens
                                          Lenovo ideapad 3 14IGL05 bios dump needed
                                          by hirens
                                          model: 81wh
                                          sn: pf36ta6h
                                          board no: nm-c961 gs453/gs553
                                          hey guys above is my laptop info
                                          it only blinks the power button kindly help me with a working dump
                                          old dump attached...
                                          07-21-2023, 04:48 AM
